Which subframes?
  • Thread starter Thread starter VTStang66
  • Start date Start date Dec 8, 2004
1 of 2 Next Last
VTStang66
2,407
Rockwall, TX
Dec 8, 2004
  • Dec 8, 2004
Mustangs unlimited sells their subframes, and some made by TCP. I don't know anything about either. The main thing about the TCP ones is that you can get their X-brace to install in addition to the regular subframes, but total cost is about 3x the cost of the mustangs plus subframes.
So which ones should I get? I can afford the TCP ones, I'm just wondering if they're that much better.
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Dec 8, 2004
  • Dec 8, 2004
Since you're getting a welder, just make your own -- it's really easy.
You can get the steel from your local supplier and there are many of us here that would be happy to walk you through the process. Basically if you can weld in store-bought subframe connectors, then you can make your own. Plus, you feel studly for fabbing something.
66 BLAKE 96
Native Texican
4,810
Cowtown
Dec 8, 2004
  • Dec 8, 2004
Howdy VT!
It's my understanding that a great (and affordable) way to go is to get Competition Engineering Bolt On subframes and weld them on. The weld-ons from CE require fabbing and I believe moving the leaf spring. The bolt-ons provide plenty of material to weld them. I think they went for +/- $100 last time I checked. I wanna say 2bav has this setup too.
Pbum5
515
Minneapolis, MN
Dec 8, 2004
  • Dec 8, 2004
66 BLAKE 96 said:
Howdy VT!
I have the Competition Engineering Bolt-ins that I also welded in. $99.88 at Summit Racing. They fit tight under the floorboards so there are no clearance problems.
VTStang66
2,407
Rockwall, TX
Dec 9, 2004
  • Dec 9, 2004
what's up blake? How is the world treating you these days?
reenmachine: what tools do I need to make subframes, besides the welder?
H
Hydrocarbon
160
Medford Oregon
Dec 9, 2004
  • Dec 9, 2004
I plan on getting TCPs sub-frame connectors. I'm going to make damn sure my frame is not going to twist.
If TCPs kit isn't good enough I'll just weld crap in random places.
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Dec 9, 2004
  • Dec 9, 2004
Good access to the underside of the car, a tape measure, some clamps, and something to cut the steel with. Pretty much the same stuff you'd need anyways, except for the cutting tools.
66 BLAKE 96
Native Texican
4,810
Cowtown
Dec 9, 2004
  • Dec 9, 2004
Great! Right now my biggest problem is trying NOT to jump on a great deal I found locally for new chrome Bullitt wheels so I can use that money to get the 5.0 and T-5 installed this winter. Good problem to have.
Sounds like you're getting back to hot rodding the car after a while off, huh?
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 9, 2004
  • Dec 9, 2004
Mustangs Unlinited
Edbert
3,548
32
109
Austin TX
Dec 9, 2004
#10
  • Dec 9, 2004
  • #10
The best thing about the TCP unit is the X-brace (as has been mentioned). If you want the X then you buy from TCP or make your own. I would have paid the extra to buy the TCP setup but it don't fit under a soft top Mustang, so I went with the Global West product. Whatever you buy weld them in, you can bolt em if you want or not, but have them welded with or without the bolt. Also make damn sure your body is straight and level before you do.
rhyno9
209
Oswego Illinnoying
Dec 9, 2004
#11
  • Dec 9, 2004
  • #11
check out the link below for a DIY approach.
RV
http://www.mustangandfords.com/howto/89059/index.html
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Dec 9, 2004
#12
  • Dec 9, 2004
  • #12
RV
exactly.
BAD67FUN
589
Wisconsin
Dec 9, 2004
#13
  • Dec 9, 2004
  • #13
You guys have consider other peoples fab skills my not be that of your own. Saying it's easy can be mis-leading. Also... some peoples time is worth more than others. An average welder/fabricator may need to spend quit a bit of time to come up with pieces comparable to the TCP set.
They may end up costing a couple of bucks more... but you can be rest assured they will work as advertised.
I'm not trying to sell any particular brand.... but I will mention that I have the TCP set, including the X brace. The difference in chasis stiffness is amazing. I could tell within the first half a block of driving it.
I'm sure every brand of connector offers some level of satisfaction.
65mistress
405
Generica USA
Dec 9, 2004
#14
  • Dec 9, 2004
  • #14
I think that reen has a point, sometimes there is nothing like saying "Yep, I made those..."
For some it's just the experience of fabricating it yourself that's worth the extra "cost"
VTStang66
2,407
Rockwall, TX
Dec 9, 2004
#15
  • Dec 9, 2004
  • #15
I came into some money when some girl smashed my truck. I'm a lot more motivated to spend days lying on my back on cold concrete when there are thousands of dollars being spent at the same time.
Hopefully by the end of winter break (mid january) I'll have a limited slip with 4.11s, 16" wheels, subframes, new wiring, a new stereo, a rattle-free interior, a new parking brake, and about 50 other little things to make the car fun again. It should be fast and awesome, I can't wait.
BB1966
297
Beaufort , NC USA!!!!
Dec 9, 2004
#16
  • Dec 9, 2004
  • #16
That is a lot of work to save $75.00.
foghorn67
I'll save you the time and choke myself
1,532
Orange County, CA
Dec 9, 2004
#17
  • Dec 9, 2004
  • #17
nice to hear.
VT: how's the condition of the fram rail thingies on your stang? Is this a factor? Mine is beat up from car lifts.
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Dec 9, 2004
#18
  • Dec 9, 2004
  • #18
You're missing the point entirely.
beanplant
548
KC MO
Dec 9, 2004
#19
  • Dec 9, 2004
  • #19
I agree with the self-satisfaction of fabrication. I don't have a welder and have somehow fabricated a lot of my parts. My dad works at a Ford plant here so he's had some of the guys workin on the side up there for us. = ) I need a mig welder though...
-Shaun
66 BLAKE 96
Native Texican
4,810
Cowtown
Dec 10, 2004
#20
  • Dec 10, 2004
  • #20
Very cool.
Let me know how you master the rattle free interior. I think there's just too much fiberglass, and too many screws to totally silence these things, but I'm hopeful.
What kind of parking brake are you going with? I snagged the brake from the 85 GT I parted out and will be fabbing it into my car in January also.
1 of 2 Next Last
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
