In order to launch a car well, you need a very loose suspension that will give you a lot of weight transfer to get the weight from the front of the car to the rear.
On the other hand, in order to corner well, you'll need a very tight suspension that will not transfer weight very well. Weight transfer is somewhat an enemy in AutoXing.
A tight suspension on the drag strip will KILL your 60 ft. time. Take my car for example. I have no sway bars front or rear, control arms, panhard bar, subframe connectors, strut tower brace, lakewood 90/10 and 50/50 drag shocks, and some sticky street tires and I'm still only getting 2.0 sec 60 ft times when they should be in the 1.7s. The reason is that I have bbk lowering springs. These springs are super tight and the car does corner well despite all the drag equipment, however, they're ruining my track times.
I'm not saying it's impossible to have the best of both worlds, but it will be very tough. Some sort of an air suspension mich help you out a bit. If you have the cash, it might be able to be done
