Which Vortech?
  • Thread starter Thread starter GearHd6
  • Start date Start date Aug 15, 2005
GearHd6
459
Ashford, CT
Aug 15, 2005
  • Aug 15, 2005
I've got a basically stock 91 Mustang 5.0 that I want to install a Vortech Supercharger on. The engine is all stock, its got shorties, catted H pipe and Flowmaster cat back exhaust. Which supercharger will work best with that combination? I'd like to get as much out of it as possible without killing the bottom end.
$uperstang
476
Detroit, MI
Aug 16, 2005
  • Aug 16, 2005
Get the Vortech S-Trim 8-10PSI perfect for the stock motor and comes with an 8 rib set-up and T-rex pump and BTM. Everything you would need!
Saleen8786
209
Marlton, NJ
Aug 16, 2005
  • Aug 16, 2005
BLUEflame68
14
New york
Aug 18, 2005
  • Aug 18, 2005
how is the sc trim
QDRHRSE
1,590
Palmdale, CA
Aug 18, 2005
  • Aug 18, 2005
If you do not plan on doing much of anything else an S-Trim would be a little big I think. Don't get me wrong, the S trim is a great blower but I think on a car that has stock heads/cam/intake you are putting your headgaskets at constant risk. I recommend a Paxton NOVI1000. Not just because I have one, but rather, the Paxton kits are a lot nicer. Also, mine as a single belt set up and an adjustable tensioner- the Vortech units do not have these. With an Anderson power Pipe and an Anderson pulley set up I see 11-12lbs of boost. That's more than enough. Vortech units are excellent as well but they are just a tad below the Paxton units in quality....keep in mind that they are owned by the same company. Also, a single belt is not withwout its flaws but it has served me well. The smaller vortech is a reliable unit as well. I guess the answer to your question depends on your future plans.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
