Which way for Oil Pump Shaft
You bumped your post after only being in the forums for less than 1/2 hour? Yikes.
The "washer" aka. the oil pump driveshaft "stop" should be towards the distributor. You want it to be against the roof of the crankcase.
Uh ohh. So the stop "washer" on the shaft goes on the top side by the distributor, and not on the bottom by the pump? Basically drop it in the way it is in his picture? Would you say it's dangerous to have it the other way? I think mine may be upside down.
Thanks..
You want it by the distributor, so if you have to pull the distributor out, you're not yanking the oil pan to put the pump driveshaft back in. They'll usually come out of the pump with the dizzy and fall down into the pan if they're in the wrong way, or the retaining washer isn't in place.
Thanks..
I wouldn't want it the wrong way, I'd be worried every time I needed to pull the distributor for anything that the pump drive shaft would fall into the oil pan.
Very sorry for the slight jack of the your thread. So if mine is in upside down would I have to pull the oil pan to make it right? Or, should I just go with it the way it is, and if I have to pull the distributor just be very very careful. Again, sorry for the jack.
Thanks....
