Which year control arms
you could use the older arms with this axle if you have the older axle bolts as well. it will bolt right in.
you can also use 99-04 arms but will have to swap out the axle bushings for the correct size and get the correct axle bolt set...the difference between years is the bolt sizes for the axle mount points changed.
