  • SN95 4.6L Mustang Tech
Whine Noise - 4.10 Gears
  • Thread starter Thread starter silver04stang
  • Start date Start date May 5, 2008
silver04stang
51
  • May 5, 2008
Hey guys,
I just recently had richmond 4.10 gears, an 03/04 cobra differential, and 31 spline axles installed on my car. I noticed that when I drive in a high gear at a low speed, I hear a whine. Is this normal? Does anyone else notice this?
scupking
1,186
Enfield, CT
May 5, 2008
  • May 5, 2008
My FRPP 3.73s whine so much so that my girlfriend says it’s annoying.
Q
quickred99
17
  • May 5, 2008
richmond gears usually whine a little i dont no why but thats just what i've heard
silver04stang
51
  • May 5, 2008
thanks for the input guys i really appreciate it. the guy that did the job on my gears does great work, but i was just wondering if this was common for anyone else. the guy that did the work is a performance instructor at UTI. the whine isnt that loud thats its annoying, but i can hear it is the music is low on and im driving in a higher gear at a low speed.
anyone have richmond gears and not have a whine??? any input would be appreciated.
BobHyatt
378
  • May 5, 2008
I have put 'em in with no whine. Most likely the pinion depth is set wrong so that the pinion/ring gear do not engage at the right point. Second alternative is incorrect backlash, which will make the teeth engage either too deeply or not deeply enough, again setting up a whine...
Pinion depth is set by shims on the front of the pinion gear and many cheat a bit here because it is a pain in the ass to set it, get it wrong, have to pull the bearing off the shaft (it is a tight interference fit) to change the shims... Backlash is adjusted by the shims on either side of the diffferential carrier between the bearings and the carrier housing.
Mossberg
ATL, Shawty
May 6, 2008
  • May 6, 2008
A proper gear installation should not whine. Period.
I would have the installer double check the specs.
I have FRPP 4.10s and have no whine.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
May 6, 2008
  • May 6, 2008
If set properly, they should not whine. If they do, you need to take it back and have them do it correctly.
BurningRubber
1,865
24
58
May 7, 2008
  • May 7, 2008
I have Summit Racing 4.10's, installed by a 30 year ASE certified mech... they whine also.
Everything checked out during the install, so it may be the brand gears themselves.
hotdog71
427
Seattle, Eastside
May 7, 2008
  • May 7, 2008
FRPP 4.10 and no whine
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
May 7, 2008
#10
  • May 7, 2008
  • #10
You should probably get that fixed asap
YellowMach69
371
buffalo new york
Nov 2, 2008
#11
  • Nov 2, 2008
  • #11
If I have Fords 4.10 gear and they whine after a install, and I have like 2,000 miles on them, will they be able to reset the gears to fix it?
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 2, 2008
#12
  • Nov 2, 2008
  • #12
silver04stang said:
Hey guys,
My FRPP 3.73's do not whine and i didn't use an install kit either. How do you like the new setup? I've got the same sitting in my trunk right now but with 3.73's that im hoping to get installed this comming week.
kalvick
352
Norwalk, CT
Nov 4, 2008
#13
  • Nov 4, 2008
  • #13
mine only whines when i am slowing down and let off the gas when i am going about 30 miles an hour coasting to a stop. if im slowing down and apply the brakes no whine.
just tell all your buddies that arn't car people you got turbo's in your differential, they will never know. tell them the whine is the turbos spooling
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Rear end noise while driving low and high speeds
  • skkrtis
  • Apr 7, 2025
2005 - 2014 S-197 Mustang -General/Talk- Feb 9, 2026
Broncin491
E
1986 Convertable 5.0 GT
  • eneerg
  • Sep 24, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 24, 2025
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
