Whining transmission
  • Thread starter Thread starter -ben-
  • Start date Start date Sep 8, 2005
-ben-
21
  • Sep 8, 2005
Ok, heres the deal. Towards the end of July I had to make a 3 hour drive from where I live. At the start of the drive, 5th gear started making a weird noise. Come to find out, when I got back home, I was low on tranny fluid. I filled it back up with the reccomended lubricant, but I think it was too late. It whines really loud now.
Heres the symptoms: 1,2,3,and 5th gear whine really loud. 4th gear is completely silent. Not sure why. When im sitting still, with the clutch out, the transmission makes a small rattling noise, and when i push the clutch in, the noise goes away. I can confirm that it is coming from the tranny, it isnt a TO bearing or anything.
Does my whole transmission need rebuilt? Or is this maybe some kind of bearing or something that I can just replace? I might have to just tear the tranny apart to find out, but I thought I would ask here first to see if anyone knew. Thanks for the help.
Sicarius428
2,085
Sep 8, 2005
  • Sep 8, 2005
My third gear whines. Sounds like a roots style supercharger... that I unfortunately don't have.
Kevin
-ben-
21
  • Sep 9, 2005
bump
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Sep 9, 2005
  • Sep 9, 2005
Just leave it and tell everyone you have a Kenne Bell
5.02GO
308
Ky, Blue Sky Country
Sep 9, 2005
  • Sep 9, 2005
Rebuilding............Good possibility.
Mine did that a year or two ago. I actually had my blower off the car and my friend still thought it was on my car. Thats how loud it was. Anyway, i was building my house when this happend thus i didnt have time to have it rebuilt. I purchased a new one. When i got the old one out, it was obvious. The input shaft had a horrible wobble. Guess a bearing or bushing took a crap.
Since the input shaft was gone i assume that the other gears were worn sharp cause they ALL whined. You may have to have yours rebuilt.
Good luck
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 9, 2005
  • Sep 9, 2005
I'd say ditto on the rebuild. Had one that did it before, only to find out when I changed the fluid that pretty much everything in the trans was worn out. Looked like someone poured glitter into my trans fluid. I could've kept driving it longer than I did, but since it was my daily driver, I opted for a new T-5. For the record, it did whine like that for around 2 months before I had the money to replace it, but I'd keep driving to a minimum if possible. It's a huge pain when you lose a gear
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Sep 9, 2005
  • Sep 9, 2005
Learn to deal with the whine.
WHen you are low on fluid, the bearings starve and beging to overheat. The main culprit is the bearing between the mainshaft and input shaft. It starves for fluid when the level is low.
It gets hot and literally scores the mainshaft. That's why you hear noise in ever geat but 4th. In 4th gear the input and mainshaft are 1:1, so nothing is turning against east other.
You'll need a full rebuild kit and main need a new mainshaft...which is $250 new.
I lucked out and found a good used mainshaft for $60 in the classifieds.
dkins419
187
Michigan
Sep 9, 2005
  • Sep 9, 2005
i just recently took my t5 out for a rebuild. It whined like a supercharger and i always got looks like wtf is that lol. The previous owner never fixed the trans leak and drove it for a while like that. All 3 of the shafts are damaged badly so now im getting a different trans.
nazstang
204
Rhode Island
Sep 9, 2005
  • Sep 9, 2005
if you have a shifter, you could need to adjust it a bit better. mine did that after a long trip in 5th, i asjusted it too tight(shorter throw)
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
