Whistle
  • Thread starter Thread starter lvmustanggt
  • Start date Start date Feb 10, 2008
1 of 2 Next Last
lvmustanggt
721
Las Vegas
Feb 10, 2008
  • Feb 10, 2008
As most of you know I have been having this whistling problem for over year now. I have change alternator, IAC, EGR, Idler , belt and tensionner and no luck.
Today I spray carb cleaner to ever vacuum hose there is and upper and lower intake
no idle change so I know there is no vacuum leak. As I listen I feel like it's comming from back of the engine and I am thinking now it maby my starter motor might be making that whistle?
Does starter whistle when it's going bad ? Where else should I look guys ? I am getting annoyed and frustrated that I am thinkning about selling my car .
Please help
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Feb 10, 2008
  • Feb 10, 2008
Could it be your C&L Plenum? I have the same plenum and it whistles under slight throttle but goes away after I give it a little more gas.
lvmustanggt
721
Las Vegas
Feb 10, 2008
  • Feb 10, 2008
I even put stock plenum and tb but still there's whistle. It's all started after my cams went in last year.
fobra559
Nov 1, 2007
721
Lindsay, CA
Feb 10, 2008
  • Feb 10, 2008
I don't think it would be the cams, did you check if your intake manifold is cracked?
lvmustanggt
721
Las Vegas
Feb 10, 2008
  • Feb 10, 2008
I checked it but don't see any crack, I sprayed carb cleaner to see if idle change but noting. My car does have idle problem as it goes up and down a little. I am thinking starter went bad or I just have to take the hole upper and lower intake out to see if it's cracked somewhere I cannot see.
fobra559
Nov 1, 2007
721
Lindsay, CA
Feb 10, 2008
  • Feb 10, 2008
Do you have your cams tuned properly? That could cause the idle problem if it's not tuned correctly. As for the whistle problem, does it only occur when driving or at idle?
lvmustanggt
721
Las Vegas
Feb 11, 2008
  • Feb 11, 2008
My car is dyno tuned, as for the whistle is starts after 1500rpm and up . At idle no whistle at all but as soon as my rpm 1500-2000 then I can hear the whistle. Every time I shift I hear like siss like BOV letting air out. When I am driving at 2000 rpm it's constant whistle. If my rpm falls down below 1500 I don't hear a thing even I am driving or idle. What can It be ?
Thank in adavance to help me out
Jacob_Royer
142
  • Feb 11, 2008
my car does it too... hopefuly my new intake makes it go away
G
GettinThere
553
Central Texas
Feb 11, 2008
  • Feb 11, 2008
If you truly don't have an air / vacuum leak, then I think it's the design of the plenum that causes the whistle. My TFS plenum whistles, and I'm 99% sure there is no leak. It only seems to whistle slightly, and only within the lower rpm range. Sounds kinda like blowing across the top of a coke bottle.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Feb 11, 2008
#10
  • Feb 11, 2008
  • #10
I had a vacume leak once I sprayed carb clean all over the motor with no luck then I found out that that type of carb clean wasent flammable, got some flammable sturf and found it
lvmustanggt
721
Las Vegas
Feb 11, 2008
#11
  • Feb 11, 2008
  • #11
I use autozone carb cleaner and it's says flammable. I will have to take things apart and look
Where was your leak ?
98COBRA281
1,348
30
59
Feb 11, 2008
#12
  • Feb 11, 2008
  • #12
pcv hose that connects to the plenium had some small cracks in it
fobra559
Nov 1, 2007
721
Lindsay, CA
Feb 11, 2008
#13
  • Feb 11, 2008
  • #13
If it whistles in the upper rpms, then it's most likely you have a crack somewhere around your intake manifold or upper plenum. Also a leaked vaccum hose can cause idle issues.
lvmustanggt
721
Las Vegas
Feb 15, 2008
#14
  • Feb 15, 2008
  • #14
It's all started after my cams install so I called the shop today and told him about the problem. Going to drop it off on thursday. Hope he finds the problem.
fobra559
Nov 1, 2007
721
Lindsay, CA
Feb 16, 2008
#15
  • Feb 16, 2008
  • #15
I hope they get it figured out and all goes well. Keep us posted.
lvmustanggt
721
Las Vegas
Feb 16, 2008
#16
  • Feb 16, 2008
  • #16
I will and thank you for your help
lvmustanggt
721
Las Vegas
Feb 29, 2008
#17
  • Feb 29, 2008
  • #17
I picked up my car today but still there's whistle. I told them to look for leak and they end up changing the lower intake gasket . I told them , I haven't change lower intake gasket so they though it might help.
They are saying they don't know what causing the whistle and it might be just air turbulence. I had to pay 298.00 for it so I am not happy at all cause I told them to do leak test before changing any thing. My wife is so mad with me for spending money on my car cause we just had a baby girl ( she is 2 months old ) so my wife is not working and I am not making money to support both of us.
Other then that my car runs fine just this ****ing whistle
Thanks
CobraRed_96_GT
1,421
UCSD/La Jolla
Feb 29, 2008
#18
  • Feb 29, 2008
  • #18
I found people have the same symptoms in Oakland: http://youtube.com/watch?v=ccgXjA2BLEY
RandyStinchcomb
1,159
Randallstown, Md
Feb 29, 2008
#19
  • Feb 29, 2008
  • #19
some of that noise could either be the IAC or the hose going from the air inlet tube to the IAC...there is a black box inline on that hose that acts as a muffler, make sure that there are no cracks in that "muffler" or the hoses
M
mustang gt 2003
29
#20
  • Feb 29, 2008
  • #20
I have the same problem with the wistle....its honestly driving me crazy and i am also considering selling my car. I believe it all started after i installed the new TB and plenum. At first i thought it was my clutch and TOB so i had everything replaced...and that didnt solve the problem. Soon enough im going to put the stock intake tube back, stock TB, and plenum to see if that helps. Hope you find your problem...so i can fix mine too!!!
1 of 2 Next Last
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
