whistling noise?
  • Thread starter Thread starter jcw88
  • Start date Start date May 16, 2007
jcw88
Never played w/ it before so i'm still a virgin!
Mar 20, 2007
53
fernandina, fl
May 16, 2007
  • May 16, 2007
i replace my upper and lower intake manifolds and upped my injectors to 24lbs. i'm now getting a loud whislting noise coming from either the idl control motor or the egr spacer and throttle body. i had a vacuum leak in the egr spacer gasket before and have replace them with a 75mm gasket, my throttle body and egr spacer is only a 70mm the local shop said this would be fine but not sure whats going on? maybe my idle control motor is bad??
cenok is family
1,409
69
79
Norman, Ok
May 16, 2007
  • May 16, 2007
first, your iac isn't a motor. it's an air bypass so your car can idle with the throttle body shut. and that could be the problem. clean it and see. as far as the gasket, that could cause it as well. since the gasket opening is larger than the bore, there's a gap between the throttle body and egr spacer that the wind might be catching, causing the whistle. shouldn't be a problem, aside from having that annoying whistle.
jcw88
Mar 20, 2007
53
fernandina, fl
May 16, 2007
  • May 16, 2007
i understand what your saying about the gasket size but my car doesn't want to idle. at least after it has ran for a few mins. i crank it up it runs good the noise starts then after a few mins it shuts off. i have no clue. i replaced my lower intake and didn't use rtv on the cyclinder head side just on the front and back of the block. maybe i'm getting a vacuum from there?
jcw88
Mar 20, 2007
53
fernandina, fl
May 16, 2007
  • May 16, 2007
my throttle body and egr spacer are both brand new so there not dirty or no build up.
AnthonyR23
661
Ontario
May 16, 2007
  • May 16, 2007
the valve is commonly called the idle air control motor
http://autorepair.about.com/cs/troubleshooting/l/aa042603a_08.htm
AnthonyR23
661
Ontario
May 16, 2007
  • May 16, 2007
try unplugging the iac when the car is running... does it idle ok with the iac unplugged?
AnthonyR23
661
Ontario
May 16, 2007
  • May 16, 2007
get a vacuum tester and make sure your vacuum is good... if it is ok.. adjust the idle air screw on the bottom of the throttle body.. with the iac unplugged... should idle at 600 unplugged... once you get it down to 600... readjust your tps with key at on position... so the voltage reads between .6 and .9.. make sure the engine is warm though before doing this... the disconnect your battery cable for about 10 minutes... then restart the car with iac plugged in.. and the comp will have to relearn but it should idle better... about the whistling could be the gasket.. if it is still idling bad the iac motor could be bad..
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Monday at 12:38 PM
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
SOLD Ported GT40 tubular upper and lower
  • Kid wita 5oh
  • Nov 11, 2025
  • Engine and Power Adder
Engine and Power Adder Nov 11, 2025
Kid wita 5oh
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
