i replace my upper and lower intake manifolds and upped my injectors to 24lbs. i'm now getting a loud whislting noise coming from either the idl control motor or the egr spacer and throttle body. i had a vacuum leak in the egr spacer gasket before and have replace them with a 75mm gasket, my throttle body and egr spacer is only a 70mm the local shop said this would be fine but not sure whats going on? maybe my idle control motor is bad??
