  • 1994 - 1995 Specific Tech
whistling sound?
  • Thread starter Thread starter inphiniti
  • Start date Start date Dec 19, 2008
I
inphiniti
412
Providence, RI
Dec 19, 2008
  • Dec 19, 2008
ok i got one for you guys, 9/10 times when i start my car up, somewhere it sounds like a tea-kettle when the water starts to boil. any ideas/suggestions? more often than none it gets REAL loud too
i was thinking maybe its my aode on its way out...again
94-302-vert
1,947
NE CT
Dec 19, 2008
  • Dec 19, 2008
Probably the CAI...
I would solve it by doing a muffler delete. Or even better a Mid-pipe delete...
I
inphiniti
412
Providence, RI
Dec 19, 2008
  • Dec 19, 2008
its only at idle, once i throw it into drive it goes away... thats why i sortve thought it was the tranny...
plus i got the stinger dumps on there now cant hear **** ... i bet once i go to a pro chamber i wont be able to hear myself cough in the car
hotcobra03
poteet,tx
Dec 19, 2008
  • Dec 19, 2008
whistle???????
maybe not but how about check valve on brake booster?????? you say it doesnt whistle when in gear,but is foot on brake?????? in park hit brake pedal and see if any changes????
Bosko5.0
1,067
longwood, FL
Dec 19, 2008
  • Dec 19, 2008
It could be throttle body or bearing in trans or bearing on an assecories.
I
inphiniti
412
Providence, RI
Dec 20, 2008
  • Dec 20, 2008
when foot is applied to the brake in park, it still makes the whistle. only when i switch the tranny into gear is when it stops.
i read that about the tb last nite, but all i saw was some aftermarket tbs doing that... the motor is currently still bone stock... what would cause the tb to whistle? does that mean its on its way out?
this car bs is never ending
HISSIN50
34
129
Dec 20, 2008
  • Dec 20, 2008
You're really sure it's not your serp belt? In cold weather, they are more prone to make noise than when the rubber is warmer and supple. The RPM change in going from park to drive could be enough to quiet it down.
Does it make any funny noises when you are on it and the trans goes to shift?
I
inphiniti
412
Providence, RI
Dec 20, 2008
  • Dec 20, 2008
now that you mention it, that could make sense... i didnt even think of that to be honest! and to answer ur question, it doesnt make funny noises when im on it/shifting. nothing out of the ordinary
hotcobra03
poteet,tx
Dec 22, 2008
  • Dec 22, 2008
what is the sound again?
you said sounds like tea pot whistle,to me thats blowing steam,air and vacuum noises....hission50 said belts,,,that a high pitch whine,squeal type noise....both are loud and change with rpms...any other discription of noise to you ear?????
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
