White Smoke
  • Thread starter Thread starter 69PaleHorse
  • Start date Start date Jul 10, 2004
69PaleHorse
264
Ventura County, CA
Jul 10, 2004
  • Jul 10, 2004
During stop and go traffic the other day I noticed a substantial puff of white smoke from my tailpipes as I accelerated from a dead stop.
Now, I have been trying to track down what I thought was an ignition misfire for about two weeks. It starts fine, but definitely is running a little rough - symptomatic of a misfire, though I have replaced the following to rule out ignition:
Coil
Plugs - not fouled and look normal
Plug Wires
Seeing the smoke makes me wonder now if I perhaps have a bigger problem than just ignition. I have had the following thoughts as possible causes for this:
Worn valve seals
Intake/Cylinder head leak
Worn piston rings
Any other thoughts? I should note that it is not consistent - the majority of the smoke seems to occur after the vehicle starts from a dead stop, such as in traffic or at a stop light.
I'll likely get the compression checked next week...
Thanks in advance for the input!
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Jul 11, 2004
  • Jul 11, 2004
If your sure its white the thats coolant getting into the cylenders. Blue smoke is oil burning. Most likely you have a leaking head gasket. While you have the heads off look for cracks. Look for bubbles in your radiator that dont go away, keep coming.
tach
74
Moreno Valley, California
Jul 11, 2004
  • Jul 11, 2004
visa versa
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jul 11, 2004
  • Jul 11, 2004
Tom is correct, white is water.
If you only see it when you start off, it's probubly only because while your driving it's evaporating before you can see it. While your stopped it's building up in the pipes.
Rent-A-Racer
187
  • Jul 11, 2004
can't white also be oil?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jul 11, 2004
  • Jul 11, 2004
Nope
2nd Mustang
2,488
Southern California
Jul 11, 2004
  • Jul 11, 2004
If it's an automatic tranny, don't forget that a leaking vacuum compensator on the tranny can inject tranny fluid into the intake manifold and cause white smoke at high vacuum conditions. My car is doing the same thing, but I think it's my pcv valve as I have a top loader tranny.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
