White Smoke??!!
  • Thread starter Thread starter FOOT2DFLOOR
  • Start date Start date Dec 1, 2004
FOOT2DFLOOR
108
Williamston, South Carolina
Dec 1, 2004
  • Dec 1, 2004
I have white smoke coming out of my exhaust, and I have a leak where my headers bolt to the heads so it comes from there to. It only smokes on the passenger side though. It smells like antifreeze, so i though i might have a bad head gasket, the thing is theyre fairly new and i havent had to put any water/coolant in it. And also it doesnt always do it just when i drive about 10 miles or so, it'll smoke a bit then stop, then drive a few more and smokes again....you get the idea... Have any of yall had this happen or know what it is?? Thanks for the help!!
bryanrevans
296
Chicopee,Mass
Dec 1, 2004
  • Dec 1, 2004
Recent head work??Recent lower intake removal???Sounds like tooo much coolant to be throttle body leakin..Though the care would suck harder and more volume at 10 miles per hour.You prob bypass egr coolant if its the one exhaust port then that eliminates everything Im thinking of sorry man!!!!!!!!!!!!!
bryanrevans
296
Chicopee,Mass
Dec 1, 2004
  • Dec 1, 2004
Took me a min to realize I was off!!!!!!!
87GT 306
260
Springfield MA
Dec 1, 2004
  • Dec 1, 2004
Mine smokes real bad. If Im at a light and it turns as soon as I give it gas you see a cloud of smoke. It smokes at WOT too. Im pretty sure that the piston rings were shot? It was too much smoke for valve seals. Cant wait to get my new 306 in.
NKau
1,346
Jefferson, WI
Dec 1, 2004
  • Dec 1, 2004
If the exhaust smells sweet, you in all likelihood have a bad head gasket. Does the car start to run a bit hot after hard driving?
Carney Woods
191
Montreal, Quebec
Dec 1, 2004
  • Dec 1, 2004
It sounds like a bad head gasket. Check your oil to see if it is contaminated. With recent head work maybe the heads weren't torqued down correctly?
F
fivepointNO
746
  • Dec 1, 2004
From the description, you've got one of 2 possibilities. #1, blown head gasket. #2, cracked head or block.
Definitely check for coolant or water in the oil. That's your biggest sign that you need to get it fixed.
88-GT
183
Dec 1, 2004
  • Dec 1, 2004
Yea when I bought my car I thought it was a head gasket too but once I looked at it sumone had put a throttle body spacer with no gasket in the coolant jacket, id check that but mine smoked constant as soon as thermostat opened, but id check ur lower intake gasket too, easy to take off and you never know.
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
  • Dec 2, 2004
With the coolant going to one side that kinda eliminates my earlier idea.As far as throttle body.But with the lower intake gasket the coolant could be limited to the passages on the side the leak is comeing from.Throttle body would be from both.I know its frightening but reallity is leaning towards head gasket!!!
J
jaackal
402
NJ
Dec 2, 2004
#10
  • Dec 2, 2004
  • #10
i put my thermostat in with the gasket on the housing not the intake and i was blowing white smoke, so i switched it up and it eliminated the smoke just me $.02
bryanrevans
296
Chicopee,Mass
Dec 2, 2004
#11
  • Dec 2, 2004
  • #11
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
