Who has boost and hyperutectics?!
  • Thread starter Thread starter Joey7508
  • Start date Start date Sep 18, 2008
J
Joey7508
198
Kerrville TX
Sep 18, 2008
  • Sep 18, 2008
Here is the deal I have a 302 with TF heads, street intake, F303 cam. The short block is a new "explorer left overs" bottom end. So new block, crank, rods, and hyper-u pistons. Has about 6,000 miles or so on it. I also just purchased a Hellion Heat turbo kit. It is a intercooled single 62mm turbo kit. I am going to put it on the car and run it on low boost ( less than 9 pounds anyway) and have it tuned by Murrillo Motorsports. I want to drive it around while I build the next boost capable motor. I am not concerned about making alot of power on this "stock" engine more just messing around with it. I know I should just wait till I get the next motor built, but where is the fun in that. So is any one blowing on hyperutectics here? If so how much? I have had people tell me both ways, oh you can't do that and it will be fine with a safe tune. Any info you have on the subject I would like to know.
TomCat
412
Utah
Sep 18, 2008
  • Sep 18, 2008
From what I've heard, I think you'd be ok assuming the engine is tuned and running well. They seem to be especially susceptible to detonation, so that should be your first priority... I've owned a couple turbocharged engines and when modding them, I ran into detonation a few times so be careful
Also you might want to look into discussions about ring-gapping and hyper piston failure under heavy thermal load. Don't know much on the topic, but I know those issues seem to come hand-in-hand with hypers.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 18, 2008
  • Sep 18, 2008
You should be perfectly fine if you stay conservative on the boost and tune. I'll be running a good bit of boost on my stock (Explorer) shortblock pretty soon, and I'm not the least bit concerned. I'm honestly more concerned about headgasket failure than I am the pistons letting go. All of us 94-95 guys who supercharge stock shortblocks are doing so with no issues.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
