who has deleted their air bags?
chaos254
467
NJ
Anybody have pics of their cars with deleted airbags? I was thinking about using the UPR kit(has both driver and passenger).
I do have another set of airbags to go back into the car but I've been debating if it even worth it. The car is no longer my daily driver, the metal bracket where the passenger bag mounts to is bent, I don't have any of the screws, and all the abs sensors/module have been pulled.
Me. Yes mine is bent too. Its what happens and in my o it will never go back in right. Now for the AB Delete.. well that don't fit right either.. Mine had unseemly gaps around it and after I got tired of looking at it...I fixed it. ;) I'll take pic when I get it back from shop.
just stick your new bags in. if you already have them. the metal supports can be bent back. take a pipe and a BMFH and place the bar on the center support coming out towards you and strike it the the metal straghtens out. usually the bent metal will cause a wrinkle in the dash as well. be shure to install the little velcro type pieces on the new bag if it doesnt already have themmakes your job a lot easier. you may have to trial fit it a few times and make adjustments but it can be done. finally be shure to pull your cluster out and spray paint your bulb blace and put som tin foil down in the socket to eliminate that pesky light
