You can get them for a good price on mustangtuning.com. Does anyone have any pics of them installed on a 99+? Anything wrong with them?
Thanks in advance,
Geoff
Thanks in advance,
Geoff
Wi-Stanger said:Do you need different struts/shocks and caster/camber with them?
SilverSteed said:Do yourself a favor and just get eibachs or another name brand. I got these and they hardly lowered the car at all! I mean nothing. I put them on and measured before and after and they actually raised the car. After about a week it was back to a little less than stock (.25") ride height. Save yourself the hassle, spend the few extra bucks, and do it right the first time...I wish I did. I ended up cutting 3/4 of a coil off and here is what it looks like now...![]()
Andy
Andy
Don't worry about this. Between the rubber isolator on top of it, and the fact that it gets compressed when installed the spring sits just fine.millatime said:if you cut the dead coil (I'm assuming you are talking about the flat part on the top of the coil) then how does the spring sit correctly? Doesn't the top need to be flat so it meets the metal part on the frame that holds it flushly?
