Who has SN95 spindles on there FOX?
Gearjamer
104
Hillsboro, Or
I've got a question for those of you who have done this convertion. I Just put a set of 95 spindles on my 85 GT. I have the stock control arms ,K-member, MM caster camber plates, and Cobra brakes. Now I can't get negative camber in my alignment. Anyone else have this issue? The alingment shop said my chassis is tweaked which is possible. The car had been in an accident before I got it.
Thanks,
Bill
No problems here either but to correct it you can elongate the strut mounting holes to the spindles. Take the 2 upper holes and elongate them inboard. When you go to tighten them back up make sure you are holding the spindle in the negative most position.
I'm going to be looking into having the frame checked and fixed if nessassary. My final plan is to install a MM k-member and Evolution Motorsports Tri-link with watts link out back. I'll have some extra parts left over if anybody is interested.
Global West track link, caster camber plates, front control arms with Del-a-lum bushings, and springs.
-Bill
-Bill
Ya know if youre already going with MM up front, they make a pretty damn good 3 link (torque arm) for the rear... just a thought.
DD
:flag: :nice:
