Who here has driven 100,000 problem free miles on their Stang?
  • Thread starter Thread starter Seraphitia102
  • Start date Start date Sep 17, 2007
  • 3
First Prev 2 of 3 Next Last
whyask
735
Sacramento
Sep 18, 2007
#21
  • Sep 18, 2007
  • #21
stock upper intake and a 150 shot Nitrous=BLOWN
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Sep 18, 2007
#22
  • Sep 18, 2007
  • #22
mransr said:
lets see...at 100K I think my intake manifold had been replaced..
since then the alternator an clutch at about 120k...and I just changed the gears at 184K (but that was WAYYY over due)...oh and I changed a front hub assy, but I don't think it really needed it, but after 150k it couldn't hurt
I change the oil at 5,000 miles (Castrol with a Motorcraft filter) and the gear and trans fluid every 50K (with Royal Purple)
I've been through a few sets of plugs and shocks and belts too...
did your plastic intake manifold crack?
BurningRubber said:
Almost 123k, no problems currently aside from worn out coil packs and a slight oil useage which I feel is a PCV issue.
Beat the crap out of it, taken it to the track, autocrossed it...
nice
DaNd4Speed
180
Patterson, NY
Sep 18, 2007
#23
  • Sep 18, 2007
  • #23
IAC valve at 60k miles, transmission rebuild and clutch at 100k miles, outer tie rod ends at 110k miles. Other than that I've been really happy with my stang with 112k on the clock, 12k of which are on the Vortech.
XtorT'r
381
Minnesota, YAAA
Sep 18, 2007
#24
  • Sep 18, 2007
  • #24
Under 100k I only had to change a wheel bearing but my trany has had what I think is a bent fork and some craptastic syncros since about 60k, 50k later it's still working.
109k I replaced my engine while upgrading cams because I found Ford slipped up with my engine in the factory. It made it 109k and would have made it alot more but I didn't trust it seeing occasional track duty and cross country trips being a summer DD. Plus to be honest I've always wanted to swap an engine.
oil always synthetic all around.
Every 3000-4500 miles for the engine.
Once a year for the trans and rear end.
Coolant, meh, when ever I felt like it.
I still haven't had my intake pop on me or had a plug blow out.
281CI96Coupe
233
#25
  • Sep 18, 2007
  • #25
Ball joints seized up
Intake Manifold Crack
New Alternator (from Intake Manifold spraying coolant behind it)
New Radiator - It was 10yrs old
Other than those things, great car.
RedDaemon
3,470
9
108
Atlanta, GA
Sep 18, 2007
#26
  • Sep 18, 2007
  • #26
almost 90k here
replaced the IAC a few times
replaced brake pads
replaced the complete clutch assembly at ~70k
replaced the plugs and COPs just over the summer
all fluids were changed out 2 years ago
just really maintanence...nothing serious...except for a rust problem in my trunk reservoir/canal...whatever the hell its called
streethorse
1,042
Dallas Texas
Sep 18, 2007
#27
  • Sep 18, 2007
  • #27
my 99 had 110k on it when I totaled it. I bought it at 48k. Right before I
was going to sign off I went to look at the engine 1 more time and I saw
a little green drip coming out of the intake manifold (pre stangnet days)
So they actually replaced it and I bought it the next day. But other than that
only the IAC and the battery. ( battery at105k)
mransr
1,188
36
98
Riverside, SoCal
Sep 18, 2007
#28
  • Sep 18, 2007
  • #28
yup...it had a hairline crack that drove me nuts for a summer until it finally broke ...Ford reimbursed me for the parts but not the labor (mostly 'cause I did it myself and had no receipt)
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,046
224
Massachusetts
Sep 18, 2007
#29
  • Sep 18, 2007
  • #29
My 1988 has 105,000 miles
Other than routine maintainence...only part to ever fail at a bad time was the water pump. Was a $50 fix and took one afternoon.
Seraphitia102
Oct 11, 2004
737
California
Sep 18, 2007
#30
  • Sep 18, 2007
  • #30
did you get an electric water pump?
mazen189
424
I.E. southern california
Sep 19, 2007
#31
  • Sep 19, 2007
  • #31
i gotta 98 gt, 150k miles, i finally got a head gasket problem. good thing about it is, new motor comes in .
Seraphitia102
Oct 11, 2004
737
California
Sep 19, 2007
#32
  • Sep 19, 2007
  • #32
the intake manifold cracked due to normal usage (no nitrous)? I wonder if I should replace mine for the heck of it.
mransr
1,188
36
98
Riverside, SoCal
Sep 19, 2007
#33
  • Sep 19, 2007
  • #33
it was the plastic water cross over that cracked...enough of them cracked that Ford exttended the warranty
Seraphitia102
Oct 11, 2004
737
California
Sep 19, 2007
#34
  • Sep 19, 2007
  • #34
does this mean I should replace mine?
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,046
224
Massachusetts
Sep 19, 2007
#35
  • Sep 19, 2007
  • #35
Nope, i stayed with stock mechanical. Car was a DD at the time so i needed reliability.
I've always beleives electric pumps should be reserved for weekend toys or race cars...not cars driven on the street every day for 10,000 miles/year
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,046
224
Massachusetts
Sep 19, 2007
#36
  • Sep 19, 2007
  • #36
Do you have the aluminum coolant crossover, or the plastic coolant crossover.
The problem was with the plastic crossover cars cracking the plastic. Ford upgraded to an aluminum peice halfway through '01 and that fixed the prob
if you have AL, you are fine
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Sep 19, 2007
#37
  • Sep 19, 2007
  • #37
Seraphitia102 said:
What happened?
the 3650 let go after a hard launch on slicks
Seraphitia102
Oct 11, 2004
737
California
Sep 19, 2007
#38
  • Sep 19, 2007
  • #38
I don't know if I have an aluminum coolant crossover. Is there a picture of how it looks like?
Seraphitia102
Oct 11, 2004
737
California
Sep 19, 2007
#39
  • Sep 19, 2007
  • #39
I didn't know the electric water pump is for weekend cars. What's wrong with them? I know Meziere advertises a hp gain, but not much else about daily driving.
mransr
1,188
36
98
Riverside, SoCal
Sep 19, 2007
#40
  • Sep 19, 2007
  • #40
electric water pumps don't generally have the long term durability of a belt driven pump...they are typically for cars that need every last bit of horsepower...I don't think I'd want one on a daily driver...
this is what an intake with an aluminum cross-over looks like
(hope that worked)
you could always get a Trick Flow or an HPS all aluminum intake and get it polished up for some extra under-hood bling
  • 3
T
For Sale 1984 1OWNER 20ANV 19K ORIG MILES, FOR SALE
  • tedjones
  • Mar 29, 2025
Fox Body Mustangs For Sale (1979-93) Mar 30, 2025
tedjones
T
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Yesterday at 5:19 PM
manicmechanic007
