4MuscleMachines said:Count me in!
xoxbxfx said:Just for a price idea, turbos are $300 each (for a small t3/t4)
65ShelbyClone said:I hope the kit isnt going to come just one of those. The T3 turbine will be way too small to run as a single. The only reason to run two T3/T4s is if you can get the bigger compressor to run more efficiently in this application. You can still split a 302 with two .60/.63 A/R T3s.
mtbdoc said:Very interested in this topic as well. Although I have already done the shock tower removal on my 66 'vert, I am not sure if I want to go that route on the 65 or not...so I would be curious as to what kind of turbo setup would fit with a different suspension approach. Also, a 351 block moves the heads higher up in the engine compartment. Will that help with the turbo plumbing?
180 Out said:Did you consider making it a rear turbo kit? It seems like that configuration would be easier to make a universal kit out of. The system basically picks up at the header collector, and routes the exhaust into a Y-connector then to a single turbo, then ducts the pressurized intake air back up to the engine compartment. All the turbo hardware mounts in the rear, around the axle and fuel tank, where there's not a lot of variation from year to year. I know the Fays2 Watts link I installed in my kids' '65 is the same for all years, '65 through '73. You could also consider oval exhaust pipes from Dr. Gas, for additional ground clearance.
Here's a pic of an off-the-shelf kit, sold by Squires Turbo Systems ("STS") for $4000 complete, installed in a '95 Firebird:
This is all you see under the hood:
Here's the writeup I stole these pix from: http://chevyhiperformance.com/techarticles/148_0502_turbo/#
Here's a quote:
"Since these systems are uniquely designed to function at the rear of the vehicle, it operates without any noticeable lag and will produce full boost below 3,000 rpm. This is because the intake-tubing volume is about the same size as most traditional turbos that are front-mounted with an intercooler. The system is a true bolt-on kit that can usually be installed in an afternoon. In an F-body, the intake tubing is routed under the car on the driver's side. The tubing's exposure to ambient air alongside the car also serves to cool the charge. Tests have shown that turbo outlet temps with 5-psi boost measured 175 degrees F (at the rear of the car) and dropped to 115 degrees F at the intake discharge up front. The pressure drop was 1/4 to 3/4 psi. The bottom line is that the intake tube acts as an intercooler, dropping the rear-mounted turbo temp (which is already lower than engine compartment installations) about 50 percent and with a very small drop in psi."
This magazine story includes a dyno chart showing a stock 347 ci LT-1 at 273 rwhp @ 5000, 302 lb-ft @ 4000, and one with a kit, running at 7 psi, at 385 hp @ 5300, 445 lb-ft @ 4000. Torque was over 400 lb-ft from 3000 to 5000.
Granted 5-7 psi is not much boost, but keep in mind this kit is designed as a bolt on for a fairly high compression stock engine (10.1:1 - 10.4:1 for a Cambird LT1, depending on model year). Also, how many old Stangs can handle 400-450 lb-ft at the wheels anyway?
Here's STS's site: www.ststurbo.com
Are you sure about that? STS offers all these kits, some of them for brand new cars and trucks:xoxbxfx said:i dont even onsider rear setups an option. The problem is the fact if you spool that turbo and it gets nice and hit, a simple puddle is going to kill the turbo casing. Rear turbo units are great for weekend warriors but it defeats the purpose. Turbo cars make power and are reliable enough for daily driving. A rear turbo kit is not for a daily.
180 Out said:Are you sure about that? STS offers all these kits, some of them for brand new cars and trucks:
* LS1 Camaro/Trans-Am - $3995 MSRP
* LT1 Camaro/Trans-Am - $3995 MSRP
* Chevrolet/GMC/Cadillac Trucks - $3995 MSRP
* Chevrolet/GMC/Cadillac SUVs - $3995 MSRP
* Pontiac GTO - $4495 MSRP
* H2 Hummer - $5195 MSRP
* Toyota Tacoma - $3595 MSRP
* Toyota Tundra - $3995 MSRP
* Dodge RAM 1500 Hemi - $4995 MSRP
* 1990-1993 Acura Integra (Tuner kit) - $3595
* '99-'04 C5 Corvette (Twin Turbo) - $7995
* '97-'04 C5 Corvette Tuner System (Twin Turbo) - $6995
* 2004-2005 SRT10 - $8495
* 2005 Mustang GT (Twin Turbo) - $7995
It's hard to believe that guys would buy brand new cars and trucks and spend $4000 - $8500 to turn them into weekend-only toys, all for the sake of another 100-200 hp. The Chevy mag writeup I linked to specifically says something about putting a K&N sock over the K&N air filter to protect it from mud and rain. I don't know why you'd worry about weatherproofing the air filter if you're going to warp or crack your turbo housing the first time you hit a puddle. What I'm thinking is the tailpipe is always A LOT cooler than the exhaust manifold, so maybe the turbo doesn't get all that hot way back there.
Hey, just asking, I have no idea of the answers myself.
, but from the STS FAQ page -- http://www.ststurbo.com/f_a_q :mtbdoc said:Very interested in this topic as well. Although I have already done the shock tower removal on my 66 'vert, I am not sure if I want to go that route on the 65 or not...so I would be curious as to what kind of turbo setup would fit with a different suspension approach. Also, a 351 block moves the heads higher up in the engine compartment. Will that help with the turbo plumbing?
