Who is runing afretmarket radiator and what brand
Slow5.0
2,554
Portland, OR
Who is runing aftermarket radiator and what brand
Since i installed Heads and cam i have little problem keeping temp down , its not blown head gasket or anything else , its just that stock radiator will not cool it down like i want
So i was wandering what kinda aftermarket radiators you guys runing
Ok guys , now i wanna know how much Fluidyne is better than stock radiator
With my setup with 180* thermostat on hot 90F day my car runs about 192-196 with low speed adjusted on TwEECer on 180 , high speed kicks on 196 , and low speed can't cool it anough
I tryed use high speed down low but i start melting fan motor connector and i tred 160 thermostat but still nothing
Do you guys think i can keep temperature on let say 180 on hot day in traffic with fluidyne ???
Lets see....with the AutoZone 3 core $100 special and the mods in the sig I can idle at 190 degrees in near 100 degree temperature. I do however have a 99 v6 electric fan wired to a realay which is on high 100% of the time.
I'm not sure why so many people have cooling problems though…really. You would think my combo is about as extreme as it gets for "cooling necessity"…and yet I have no issues. :shrug:
YEAHLOH95 said:
i would say it should work for you , i have a fluidyne and when my fan is working right, it stays on the o in normal.
Mine is on "o" with stock radiator but sensor is on back off intake (i have autometer one hook up in front) so it never gets hot , if i moved on stock location it will read hotter
