Got a 650 edelbrock and put it on last winter, ran the car and it worked fine, but try to start it this spring and all the carb does is shoot fuel into the engine like crazy, you can see it flowing in as you turn it over almost as if it is straight from the fuel pump.
The only thing that is different is the carb gasket, I changed it before starting it but I am pretty sure that that shouldn't be whats causing this problem.
Anything that can get stuck inside these carbs that would cause this?
