I'm looking for a set and my search results show that the coil springs used in early 6cyl mustangs for 67/68 are the same as the 289. The application for the springs says they are for both 6 cylinder and V8 so I am assuming there is no difference from the factory?
http://www.mustangsunlimited.com/keyword.asp?Keywords=coil+springs
(3rd set down on the page)
I am looking to swap out my 620 springs for some 6cyl springs to help with launching my car at the track.
Is this in fact correct? Can someone post a pick of the ride height with 6 cyl springs?, or if in fact there is no difference, will it be o.k. for me to cut the springs to get the desired ride height.
My fear is that the 6 cylinder (or v8) springs will raise my car up higher than the 1 inch drop 620's I have now. I want to keep the ride height the same but lower the spring rate.
