When it comes to cars, a lot of mechanics will say vacuum when asked what can annoy or frustrate the most about your job. Of course I would never throw a tool
but I've seen a lot of tools fly because of vacuum.
Here's some of what vacuum monitoring explain:
1) A steady reading of between 17" and 22" is considered normal for a stock engine.
2) A low but steady reading between 10" and 15" would be caused by retarded ignition or valve timing, or low compression.
3) A very low reading between 4" and 9" means you have a vacuum leak.
4) If the needle fluctuates as you increase the engine speed, you have either an ignition miss, a blown head gasket, a leaking valve or a weak valve spring.
5) A gradual drop in reading at idle means you have excessive back pressure or partial blockage in the exhaust system.
6) An intermittent fluctuation at idle means you have either an ignition miss or a sticking valve.
7) A reading where the gauge needle drifts anywhere between 12" and 22" indicates that your idle mixture is unstable. This is more common on carbureted motors.
8) A high and steady reading indicates that the ignition timing is too far advanced.
9) If, when you quickly close the throttle after running at 2000 rpm for ten seconds or more, the gauge needle DOES NOT jump two or more inches above what it is at idle, your piston rings are shot.
10) If the reading at idle is lower than normal, but the gauge needle fluctuates three inches on both sides of normal, your valve guides are excessively worn.
These are but only a few of the things you can learn about the condition of your engine with a vacuum gauge. Keep in mind that a blower or a turbo will create a false reading because the boost they create offsets the vacuum reading.
The following is the way to find out if you have an internal vacuum leak from a defective intake gasket:
1) Hook up a vacuum gauge to the intake manifold.
2) Fully close the throttle plate by backing out the idle screw all the way.
3) Plug up the PCV valve opening.
4) Disconnect and plug any vacuum hoses attached directly to the intake manifold.
5) Disconnect the wire to the positive side of the coil.
6) Crank the engine and observe the vacuum gauge. From 3" to 7" of vacuum (at a minimum of 250 cranking rpm) is normal. A defective intake manifold gasket will give, in most cases, a zero reading.
With a vacuum gauge, there are two easy tests you can run to determine if your exhaust is restricted (cats clogged).
First test:
1) Attach vacuum gauge to manifold vacuum source.
2) Observe vacuum at idle.
3) Snap throttle to WOT and release, while watching the gauge.
The vacuum gauge should drop to almost zero when you hit WOT. When the throttle snaps closed immediately after, the vacuum should read 4" to 6" higher than what it did at idle. It should then settle back at the same reading it was at idle before the WOT snap. This whole exchange should go from idle reading to idle reading in 2-3 seconds, tops. If it takes longer for the gauge to return to the same idle reading, your exhaust is restricted. The longer it takes, the worse the restriction.
Second test:
2) Warm up engine.
3) Observe vacuum at idle.
4) Leave engine idling for 10 minutes. Do not touch anything on the car during this time. In fact, go inside and fix some coffee.
5) After 10 minutes, observe the vacuum.
If the vacuum is the same or higher, you don't have any resctrictions. If the vacuum gauge has dropped, you do have a restriction. The more it drops, the greater the restriction. If it drops 1" or more, you have a serious restriction. 2" or more and you might as well have the exhaust welded shut. Keep in mind that a rich exhaust will clog up cats in a hurry.
