Who uses a vacuum cooling system refill tool? What brand and is it worth it?
  • Thread starter Thread starter killer5.0
  • Start date Start date May 3, 2018
First Prev 2 of 2
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
www.crazybobracing.com
May 9, 2018
#21
  • May 9, 2018
  • #21
we used to use a MAC when we ran the radiator systems in the X275 turbo car. the way it was plumbed made it REALLY hard to get all the air out of the system.
and damn right it was worth the money i paid for it. granted i was working for MAC at the time so my price wasnt what you would pay but even at the normal price it would have been worth it. it would have been the ONLY way to fill it correctly when it was a dual radiator system
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
May 9, 2018
#22
  • May 9, 2018
  • #22
It was a snap on tool i was using and i tried getting the seal as good as i could but my buddy said he doesnt think it was too bad and ill probably be allright but it could be a small leak in the tool maybe. In 5 minutes it dropped 2.5lbs. He said i should pressure test it so he gave me a pressure tester. Tonight ill pump it up to 12lbs? and see if it holds.
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
May 10, 2018
#23
  • May 10, 2018
  • #23
So i pressure tested last night...had a little air leak where my lower rad hose hooks to the waterpump...fixed that and it still was dropping slightly and realized the pressure testing tool has a very small leak so hard to tell if i fully fixed the problem...with the tool leaking a little it dropped 1.5lbs in 5 minutes. Hooked up the vacuum tool and it dropped 1.5lbs in 5 min...not sure where to go with this...should i just fill up and look for leaks? I have the original rad hoses still...my lower has the spring in it and the upper is cut and fitted with the vortech supplied piece in the middle...they seem to be not as strong when i squeeze them but they never leaked on me previously.
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
May 10, 2018
#24
  • May 10, 2018
  • #24
I left it hooked up and timed it...24min for it to drop from 20 to 15
D
Deleted member 215073
May 10, 2018
#25
  • May 10, 2018
  • #25
If the tool has a leak, it'll be impossible to tell if your system is sealed. I would fill it up and monitor it closely.
Reactions: killer5.0
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
May 11, 2018
#26
  • May 11, 2018
  • #26
I filled it up last night...so far so good lol...going to install the harmonic balancer...do an oil change and start her up and hope for the best...
D
May 11, 2018
#27
  • May 11, 2018
  • #27
Keep us posted
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
May 11, 2018
#28
  • May 11, 2018
  • #28
Well so far so good...got it all together fired it up...let it come to temp so the tstat opened and burped the system just incase any air was trapped. Let it run about 15min and shut it off...Had to head to the gym...came back and so far its dry underneath. Ill be taking out tomorrow or sunday weather depending to stretch her legs and see if im good to go.
Reactions: General karthief
First Prev 2 of 2
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
C
Help cooling issues urgent!
  • Cclaro
  • Apr 17, 2021
2K
1994 - 1995 Specific Tech Apr 19, 2021
KRUISR
Engine New to Mustangs, guidance needed on fault codes 47 & 45
  • sUdz6.0pwrstk
  • Sep 30, 2021
4K
Fox 5.0 Mustang Tech Oct 23, 2021
General karthief
G
Engine Need help with cooling system issue
  • germain101
  • Jun 22, 2020
2K
Fox 5.0 Mustang Tech Jun 24, 2020
Four eyed Maude
Cooling System Opinions
  • Christian Cornwell
  • Aug 24, 2017
Fox 5.0 Mustang Tech Aug 25, 2017
a91what
