I'm building a motor for a friend of mine. I'm using the FRPP Fox-Body conversion kit, which came with a new timing cover, water pump, oil pan, and balancer. The problem is the new timing cover is set up for a mechanical fuel pump. It also has a hole for the old-school, front-mounted dipstick tube. What did you guys do to block off the dipstick hole? Where can i get a block off plate for the fuel pump opening? His old timing cover broke when the motor blew up, so I can't re-use it. Motor is going into a '90 vert. Thanks
