- Sep 4, 2004
- 315
- 0
- 16
like the title say, why to after market gears whine? they seem to be a very popular thing, but why do after market gears whine, and if you get the same gear option on say an f150 from the factory the dont?
JonJon said:they shouldn't whine, whine is a sign of improper install...
Not true. Richmond gears are known for just making more noise then others. So are quite, other arn't. If you have a tight backlash, low get of gears like 4.10's, and are still in the process of the break in, then gear whine is normal. If gears were installed improperly you'd know it.JonJon said:they shouldn't whine, whine is a sign of improper install...
BossShinoda9701 said:I noticed a whining noise after I put my tri-ax and alum driveshaft on. Dont know if it is from the shifter being metal on metal contact with the tranny (just used silicone to seal it) and acting like a tuning fork, the driveshaft, or my tranny being low on oil even thought I check it once every two months?
GT JAY said:D/S.
Did you line the yellow dots on the D/S up with the one one the axle flange when you installed it? There are 8 different bolt holes on the flange, therefore there are 8 different ways to install it. Try all 8 and see if the whine goes away.
. Normally gear whine is associated with improper install, although not all the time. As stated above, some gears make more noise than others. Ive heard shops say that Richmond is the loudest, Motive, then FRPP. Ive heard of some shops refusing to install anything but FRPP because even with proper backlash and all, the gears still whined from other brands.StangLou said:Somebody didnt check their backlash. Normally gear whine is associated with improper install, although not all the time. As stated above, some gears make more noise than others. Ive heard shops say that Richmond is the loudest, Motive, then FRPP. Ive heard of some shops refusing to install anything but FRPP because even with proper backlash and all, the gears still whined from other brands.
