why do mini starter come with solenoid on them
Convention and load delivery - Most solenoids are piggybacked. And mini's are often high torque units, they want the solenoid close to the starter itself.
The year of your Mustang will determine how that piggy back starter needs to be wired too. What I mean is... There are a couple of things on the older Fox bodies that need to be changed around. The power feed wire for the mini needs to be swapped over to the unswitched side of your fender mounted start solenoid and only the mini's solenoid trigger wire is wired to the switched side of the fender mounted solenoid.
i ahve a 91, how should i wire it? and how the hell am i supposed to fit that battery cable on there? i alread how a power wire form my 3g? thanks alot man.
good thread guys
I have a 88 5.0L, anyone have a wiring diagram on what exactly were supposed to do? Or a very detailed, step by step how-to
I ordered one last week, and expecting by the end on this week
Thanks
Cameron
On the old starter, there is a thick wire running down from the fender mounted solenoid to the starter. That thick wire's position needs to be moved. Remove it from the switched side of the fender mounted solenoid to the unswitched side.
Then take the solenoid trigger wire from the new starter and wire it to the post on the fender mounted solenoid where the thick wire used to be (the switched side).
oh ok, I see
the thick wire that runs down to the old starter becomes a constant live wire (power wire), and the trigger wire that comes with the starter becomes like the "remote wire on an amp" just tells it when to fire the starter
Not to hard..................thanks guys, know I know how to wire it
Is there a ground wire on the starter, that has to be installed aswell
Thanks
Duro
StangPlus2Birds has recently posted detailed info on the mini starter (he does not post much so it should be one of his last 5 posts).
Duro, I understood your question - you think your battery lug on the solenoid is not long enough to add yet another power cable, right?
OEM solenoids have longer lugs than some aftermarket solenoids. Otherwise, a distribution block would work (I am going to install the one I have next time I have those cables apart).
Good luck.
