Why does my LMAF only have 4 pins?
  • Thread starter Thread starter blownlxvert
  • Start date Start date Jan 23, 2007
blownlxvert
48
endicott n.y.
Jan 23, 2007
  • Jan 23, 2007
# m-12579-l54 has the 6 pin plug on it but only 4 pins in the connector, is this right? the # on the electronics is 1l3f-12b579-ab.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 23, 2007
  • Jan 23, 2007
The only Ford MAF that is a one for one swap into a 5.0 Mustang is the 94-95 Mustang 70 MM MAF. The calibration for all the larger Ford MAF's isn't close enough to do a good job.
The 2 extra pins on many of the other MAF sensors are for the ACT.
blownlxvert
48
endicott n.y.
Jan 23, 2007
  • Jan 23, 2007
ummm. i know its not a direct plug in, i have a jumper coming. im trying to make sure the place i got this from isnt screwing me. its a lmaf but it only has 4 PINS inside a 6 PIN CONNECTOR. it doesnt seem right.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 23, 2007
  • Jan 23, 2007
The jumper or pin count isn't the problem, it is the calibration of the MAF sensor element to the housing and to match the computer's internal program. Without a tweecer or custom dyno tune & chip, there is no way that the calibration will be right. MAF's are not interchangeable between sizes with the limited exception of the 70 MM 94-95 Mustang MAF.
vristang
4,933
101
124
Seattle
Jan 23, 2007
  • Jan 23, 2007
JRichker is right.
You will need a custom tune to run the LMAF.
IIRC, the LMAF does not utilize all of the plugs. There are a couple of dead spots.
How are you planning on doing the tune...
jason
sweet88gt
334
Venice FL
Jan 23, 2007
  • Jan 23, 2007
Sorry to highjack your thread. If you are using the 6 pin meter and the addition 2 pins are for ACT, is this a better reading for ACT than in the intake?? I am currently using a PMAS blow thru with 6 pins, 2 of which I am not using are capped off. Thanks
vristang
4,933
101
124
Seattle
Jan 23, 2007
  • Jan 23, 2007
Because Ford used the ACT in our computers based on it being located in the intake, I feel it would be best to leave the ACT in the intake. Moving it closer to the MAF would change the way the ACT affected ignition timing advance and fuel PW's.
With that said...
Many guys have had to move the ACT to the intake tract, and reported no ill effects.
I just don't think it would be worth it...
jason
blownlxvert
48
endicott n.y.
Jan 24, 2007
  • Jan 24, 2007
not to be a dic$ guys, but you are all answering questions that im not asking and already know the answer to. i know about the plugs, the car is getting tunned yada, yada. IS THE 01-04 LMAF SUPPOSED TO HAVE 6 PINS INSIDE OF THE METER?
just4bob50
504
Pa.
Jan 24, 2007
  • Jan 24, 2007
Yes the meter is supposed to have 6 pins in the housing for the plug. You should be using the 4 center ones. When I did my conversion to the 90mm LMAF and 42lb inj. I bought the plug that fit the meter and then spliced & soldered the wires into the the factory harness. What I was thinking of doing was using the other 2 pins for a 2nd air temp sensor in the discharge tube before the TB to help the tune the car.
Brn N Rubr
Moore, OK
Jan 24, 2007
#10
  • Jan 24, 2007
  • #10
My LMAF only had four wires in it as well. The two outside pins were not used.
blownlxvert
48
endicott n.y.
Jan 24, 2007
#11
  • Jan 24, 2007
  • #11
thats how mine is, whats the deal?
Brn N Rubr
Moore, OK
Jan 24, 2007
#12
  • Jan 24, 2007
  • #12
I am using a TwEECer to tune mine and everything seems to be just fine. I have mine setup in a blow-through application with a turbo.
vristang
4,933
101
124
Seattle
Jan 24, 2007
#13
  • Jan 24, 2007
  • #13
Ford wouldn't develop a new 4 plug harness just for a single application.
Most likely, all six weren't needed for the LMAF, but may have been needed in another application that the same plug was used for.
Look at all of the plugs on the Mustang. It isn't uncommon to find a couple of dead connectors in a plug.
The computer plug is a great example of this.
jason
Electrical Going crazy trying to identify burnt and disconnected wires 83 GLX5.0
  • x_man586
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
AeroCoupe
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
Ecc pin out #4
  • 5.0buggy
  • Feb 24, 2025
  • Other Auto Tech
Other Auto Tech Mar 14, 2025
89ripper
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
3K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
