As you can tell from the title my oil seems to get dark alot quicker then it should be. Since the rebuild the first 2 oil changes did it and i figured it was normal from the assembly lube getting in the oil and just still being broken and stuff. Even right after a fresh oil change i can see the difference in shade after like 2 weeks. The weird thing is if i check it as soon as i turn off the engine its nice and clear but if i check it after the car has sat for a few hours its alot darker?? BTW i had just switched to Mobil1 synthetic after 2,000 miles and still does the same thing. If it matters i took off my upper and the ports look wet, i dont no if its gas or oil? and i also have a see through inline glass gas filter in the pcv line but it doesnt look gunked up. Should i whip out the leakdown tester to check for any blowby.
