Why does my steering wheel shake? And Why does my front wheels sit like this -> / \
Red/1995/Snake
188
America
Hello, everyone
Here's some more questions to throw out there. I have an annoying shaking steering wheel while normaly driving, it shakes side to side. Any ideas what to replace or how to cure this problem. Also both my front tires sit at an angle like this ---------------> / \ <----- any ideas how to fix this, I have gotten alignments, but it doesn't cure it. My mods list is below if it will help to determine anything. Thanks greatly for any advice. :nice:
You'll have to get your camber readjusted to fix the toe in on your wheels. My steering wheel shakes on me when I'm braking from a high speed... don't know whats causing it.
Thanks guys for the advice, never thought my tires could be bad, that really stinks. Good quality tires are so expensive :(
To Mr:1105 I have had that problem with braking, mine was affected by warped rotors, I replaced them and never had the problem again. Just a thought you might consider, thanks for your advice. : )
Ya, rotors are price. The thing is when I replaced mine I got the same kind(stock). When I could have bought those cross-drilled or those brembro cryo treated ones which are the same price and a lot better. Oh well, live and learn, you might want to check the better ones out when you get the molla.
1105 said:
I've heard about that rotor thing, Just dont have the money right now to change them and its not bad around town.
just get them cut, it costs like 10 bucks a piece, doing that stopped my steering wheel shake on braking
ya, just go to a brake shop and have them shaved/turned. I had taht done and it would of been the end of my braking and wheel shaking problems if my ABS decided not to take a $hit on me that same day.
-Drew
Well, my steering wheel shakes at high speeds, like 85+, and I was told to get my tires rotated and balanced and that would fix it. I don't know how much this will help, but I trust the guy, he knows what he is talkin about. I will let you know if this works.
