Why doesn't my car make boost in 1st gear?
You should be making boost any gear as long as you're under load and at decent RPM's.. perhaps your boost gauge is tapped to a weak line or something.
What gears do you have? With 4.10's I don't make much boost in 1st because it is so short that it doesn't have time to build up. The rest of the gears I make 9lbs
Stock 3.27 gears
how high are you letting it rev in 1st?
Up to 5800-6000 rpm
I'll check, but I think it's on a good vacuum line.
Weird. I'll check with Vortech, but I figured it was because 1st gear is so short anyways. I know my buddy with '03 Cobra makes boost in 1st gear, but he's got a roots blower.
Any chance my bypass valve isn't working right?
its because the car is too weak!!
haha im jp playin, dang hope you get that fixed before we line them up.. my car makes quite a bit of boost in first (well sorta).. well get that fixed and maybe ill see you around!
Something isn't right. I have 4.10's and I see full boost in 1st gear. Boost is dependant on RPM. You have to look real fast, but mine spikes upto 15lbs of boost. Things to look for...belt slip, bad bypass, improper boost gauge install.
I see good boost in 1st gear with 373. I agree maybe your guage isn't working. And if you are smoking your tires through out 1st and some of 2nd i would think that you are making some boost. GL with the problem it doesn't sound like anything is to wrong.
