Why doesn't my fuel gauge work?
Agreed with Bladez
Dont forget about the anti-slosh module (if 90's have them. Early aero foxes did). A bad connection there would keep the gauge from articulating.
Good luck.
HISSIN50 said:
Agreed with Bladez
Good luck.
So when I change my dash bulbs if the fuel wire is connected...I'm gonna have to drop the tank and replace stuff in there most likely? Wouldn't be so bad if my fuel pump was bad and needin fixins, but it's fine, even quiet! :(
The issue can really be anywhere along the entire system, from gauge to sending unit. If the wire is open (is cut), that can be along the entire run from dash to tank. Ohming out the sending wire could be revealing. And tracing the sending unit wiring as far from the dash as you can (when you have the cluster opened up) is a place to start.
I kinda have the feeling the issue is more likely to be at the tank-end of things though. We will see if Bladez agrees.
Good luck.
Trust me my friend, it's not as bad as it seems. I literally just got out of the shower from doing this job. It took me at most hour and a half and that's including going to the store to get me a new 2 ton aluminum jack :D My gas gauge needle was showing so full it was off the scale. Here is why, this is how I pulled my sending unit.
This is what it should look like:
And can anyone tell me what could have caused one of the metal corners to bend like this?
Like I said, it's not that big of a deal to drop the tank.
3 Bolts
2 Fuel lines
2 Wire harnesses (fuel pump & sending unit)
and the filler tube, which I didn't even pull out all the way.
I would start by checking the fuel sending unit. I just replaced mine while doing the fuel pump and after 6 years with no fuel guage its finally working :nice:
Put a multimeter on the sending unit to check its resistance through its range of motion, resistance should increase as the float moves up. Good luck.
Thanks everyone. I'll check the connection when I do the dash bulbs and then I'll drop the tank when I get some time. Looks like that fuel sender part is around $80-$90? I don't want to go through the trouble of installing a used part so I guess it's worth it. Kind of like door lock motors. If I'm tearing my door apart, I don't want to do it again for another 15 years. :)
