Why don't my reverse lights come on?(5 Spd.)
iwashmycar
Apr 7, 2004
1,236
Columbus, Ohio
I noticed the ground behind me being awful dark while backing up at night, so I asked a friend to look while I had it in reverse, and NO LIGHTS.
What could cause this? Somethin' must not be making a connection, but I don't know how Ford hooked em' up.
Thanks,
Adam.
There is a switch on the outside of the tranny. I don't know exactly where it is, but yours could be bad. Find out where it is, (maybe from a Haynes manual?) and check the connection to it, if that doesn't work, then replace it.
Crawl underneath with a test light. On the driver's side of the tranny near the rear is a switch that screws into the side of the tranny - it'll have two wires going to it. It's the reverse switch. Pull the wires off. Turn the ignition switch on. Ground your test light - one of the wires should be hot. Jumper the hot wire to the other wire - when you do, your back up lights should come on. If they don't either both bulbs are out, or you have a discontinuity in the wires going to the lights. If they do come on, then the switch is probably bad. If neither wire is hot, then the fuse is probably blown.
cardudeusa said:
Same thing with my 87, except it has no wires to hook to the tranny. The tranny has the connector but the car has no wires to hook it to.
Those wires just go up under the center console. I would bet if you pull the center console out, you'd find them tucked up underneath.
ratrapp said:
the switch is on driver side of the tranny.the other switch is the neutral sensing switch on top of the tranny(not excessable with it still in the car)
Is it the thing with the 2 treaded prongs stickin out. Made of rubber? I pulled off some connector in that general area and that is what i got. :shrug: I didn't trya nd remove the thing from the tranny yet.
