  • 1994 - 1995 Specific Tech
Why is my car harder to crank when it is hot?
  • Thread starter Thread starter 94gts
  • Start date Start date Dec 7, 2006
First Prev 2 of 2
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 8, 2006
#21
  • Dec 8, 2006
  • #21
I replaced all of the cables when I swapped engines due to this very problem. Not sure which was the problem, but they all appeared to have corrosion on the wires down inside the insulation. I say try that route first because 8 feet of welding cable and some connectors is about $100 cheaper than a new starter.
reddy351
560
12
38
Columbus, Ohio
Dec 8, 2006
#22
  • Dec 8, 2006
  • #22
final5-0 said:
What would there be in the pcm that would make your car crank with a slower rate at normal operating temp than when cold
Grady
I never said anything about the car cranking slower because of the PCM. I said that the ECM pulls timing to make the engine easier to crank >>only when the key is in the "start" position<<. Even the old Duraspark boxes do that. If the trigger wire to indicate the key is in the "start" position is not connected, the PCM will not retard timing meaning that the engine will be harder to turn over, during starting.
Capishe?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 8, 2006
#23
  • Dec 8, 2006
  • #23
Capishe?
Thats fine Rob
However, I did not quote you or anybody else for that matter.
You were not the only member to talk along those lines.
In no way was I trying to imply anything negative about your post or thoughts.
As always, I was just trying to join in on the discussion with everybody else
Peace my SN friend as there is no need to feel defensive as I did not mean to be on the offensive
Grady
reddy351
560
12
38
Columbus, Ohio
Dec 8, 2006
#24
  • Dec 8, 2006
  • #24
No offense taken. It's an open forum. For discussion. That's all it was. We're cool. :SNSign:
95Vert
1,785
North Mexico (deep south Texas)
Dec 8, 2006
#25
  • Dec 8, 2006
  • #25
I say it's the cables. Check that before getting all worked up into what others mentioned.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 8, 2006
#26
  • Dec 8, 2006
  • #26
I gotta agree
Something is drawing too much current.
If it ain't one thing its another
Especially since our cars are getting as old as they are
Grady
94gts
873
Carmel, New York
Apr 2, 2007
#27
  • Apr 2, 2007
  • #27
well 4 months later i finally put a jumper cable to the frame and it changed nothing lol
First Prev 2 of 2
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
  • dan50
  • Jul 18, 2026
dan50
