  • 1994 - 1995 Specific Tech
Why is my
  • Thread starter Thread starter 215what
  • Start date Start date May 22, 2005
215what
154
NM
May 22, 2005
  • May 22, 2005
why is my temp gauge going to the M,A with my a/c on it's about 100 out here this is making me mad i cant use my a/c what's going on should i trust my temp gauge? with my a/c off it stays on the O. my a/c is pissing me off now it is to hot with out
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 22, 2005
  • May 22, 2005
That is somewhat normal. Mine does the same.
Just make sure your fluid level is good in the radiator, your electric fan is running at both speeds, there is no debris in front or behind the radiator, the fins are not all bent, thermostat is working properly & you have equal pressure at both the lower and upper radiator hoses.
Other then that, there is nothing you can do. As long as your car is not overheating, you are ok.
Scott
J
jasonlee0704
219
Kansas City, MO
May 23, 2005
  • May 23, 2005
I live in Oklahoma, today was in the mid-90s (before heat index was factored in) and on the highway, my temp gauge was at O to R without the A/C and at R to M with the A/C on.
If it's bugging you, I agree with mo_dingo on what you can do, and also buy a $1.00 coolant tester to see how close to 50/50 your coolant mix is. The one time I've overheated, my coolant was something like 95% coolant (water was evaporating through a leaky hose seal).
HISSIN50
34
129
May 23, 2005
  • May 23, 2005
Scott, good timing.
can you let me know where you run exactly temp wise (per an aftermarket gauge or a letter on the stocker) in given conditions (A/C on, A/C off, on the highway, etc)?
I am curious what is normal in 109* heat. (I am thinking of swapping in a new radiator - the 94 runs a bit hotter than the 88 and is freaking me out a bit).
if you can, thanks bud. chat later.
juiced_94gt
1,143
Southern California
May 23, 2005
  • May 23, 2005
mine runs at 220 with the a/c on with my autometer mech. gauge, but in going to look at the water evaporating since i have a coolant leak coming from the timing cover.
juiced_94gt
1,143
Southern California
May 23, 2005
  • May 23, 2005
oh yeah and i have a fluidyne
215what
154
NM
May 23, 2005
  • May 23, 2005
how to check if fan's is goning on both speed's?
H
harley02
110
Tarpon Springs, FL
May 25, 2005
  • May 25, 2005
Just for a little heads up. I was told that when I bought my car that there was a small leak in the AC system. Now, I knew this going into it and the AC worked like it should during normal city driving. However, on the freeway when I turn it on the temp immediately shoots up to the M-A on the gauge. I can tell when the fan kicks on, but its not normal for the car to run this hot, even w/the ac on. Around town it runs at the O-R on the gauge.
I have an AC specialist told me that due to the leak, either compressor or line, that this makes the compressor work harder which makes the car run warmer.
R
Rjovi
44
Co
May 25, 2005
  • May 25, 2005
I would like to know this also.
I have all these same problems when I use my AC.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
