why no holleys?
Mar 31, 2005
427
why does it seem like few people on here run the holley intake compared to cobra/trick flow/ and edelbrock? is there any real disadvantage when looking at it for an initial upgrade with stock heads/ cam, and looking for a 300 rwhp h/c/i set-up later? the only real reason i dont care much for trickflow and edelbrock is i dont care much for the finishes they offer, and the holleys look pretty sharp unfinished/polished... plus u dont see them everyday around here. any thoughts on power they make compared to the others?
It's a little taller and doesn't fit under the stock hood very well.
Like stated before the ports are larger and shorter so its a little much for a mild 302 combo, unless you rev it up!
I've run the Performer, and Performer RPM. I did loose some low end torque, but I gained up top. The rpm's that I lost torque at, I'll never see on the dragstrip.
It's an awesome intake, everyone is using it in NMRA pure street and Renegade
crap, its a sick intake... what intake comes with the holley systemax hci kit? its only rated for 350 BHP so why would they put suck a high revving intake with parts designed for a mild set-up... compatible with an otherwise stock 302?
the ports on the holley are huge compared to the performer rpm. the size of the lower ports line up almost perfectly with the intake ports on the fr 185's. it is definitely not the intake to run on an n/a 302. that is the intake i run on my blown 331.
The Holly Kit has been around for years :D
When it first came out ...........
The reviews were not favorable to .............
OEM untouched short block based N A Street Car applications
As others have said ................
Intake ports too large
and
Some said the cam was too aggressive for a mild 302 h/c/i combo
You gotta be movin lotta air to use that intake ;)
Grady
well, looks like i have 2 options... wuss ou and get a smaller intake, or step up my goals with enough power to split my block:D no, in all reality ill just get another intake, and i meant no offense to anyone by calling the other intakes wussy, its all relative to the set-up. whats the finish on the holley? and is there any other way to get that polished, but not chromed look on any of the other tried and true intakes? i know you can get a "natural" finish on the trick flow, but that would take me a lot of work to keep clean, and i just dont think i could go polish something that big without more experience already...i'd be afraid i wouldnt like the way it came out. plus with a job and college, i wouldnt have enough time until summer
The intake ports on the Holley are huge. They fit on the AFR 185's fine but when matching the Edelbrock lower on them I would have needed a major port job.
The Holley intake is the reason why Justin Timberlake named his new CD like that.
