  • 1994 - 1995 Specific Tech
wickedly stupid question
  • Thread starter Thread starter MysticKeith50
  • Start date Start date Feb 7, 2006
1 of 2 Next Last
MysticKeith50
330
Pennsville, New Jersey
Feb 7, 2006
  • Feb 7, 2006
I have tf tw heads and got the autolite 3924 plugs. Are they pregapped, or do i still gap them to .054?
stang302v8
94
carlisle, pa
Feb 7, 2006
  • Feb 7, 2006
sorry, i dont have the answer to that question but i was wandering, do u have to use those specific plugs? i bought a pair but my motor isnt ready yet, so i havent ran it with the tw heads on. if u have ran ur car with them already, what do u think of them( performance wise)?
MysticKeith50
330
Feb 7, 2006
  • Feb 7, 2006
yes i was told by tf to use them.....I am just having a little idle problem at cold.....I am going to check tps, iac, and just thought to ask this about the plugs.
95Vert
1,785
North Mexico (deep south Texas)
Feb 7, 2006
  • Feb 7, 2006
It doesn't hurt to check Keith.
MysticKeith50
330
Feb 7, 2006
  • Feb 7, 2006
i checked...they were all like .040 and now i am wondering if they should have been .054?
Iggyshane
70
Ann Arbor, Michigan
Feb 7, 2006
  • Feb 7, 2006
i allways think its better to check rather then doing something twice. plus it only takes 30 seconds to check all the plugs.
95Vert
1,785
Feb 7, 2006
  • Feb 7, 2006
Since you're running bigger heads and all, I can't say for sure. But try gapping them at .054 since you're having some idle issues.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Feb 7, 2006
  • Feb 7, 2006
They WILL need to be gapped. .050" is fine for a n/a combo. The 3924's are the most common used plug for an aluminum head and very easy to get so thats why they're the most recommended.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 7, 2006
  • Feb 7, 2006
yep, +1
MysticKeith50
330
Feb 7, 2006
#10
  • Feb 7, 2006
  • #10
hmmmm...lets say hypothetically all the plugs were at .038 to .039 could that be my problem with my cold start idle?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Feb 7, 2006
#11
  • Feb 7, 2006
  • #11
No.
Let me guess.. You start it up cold and it wants to stall and die. You have to keep your foot in it for the first few seconds to keep it running, right? Its simple to fix with a tuning device. I had that problem once. Its a cold start lean issue.
94gts
873
Carmel, New York
Feb 7, 2006
#12
  • Feb 7, 2006
  • #12
why are the gap numbers so high?
my gt40 iron headed/nitrous set up i had stock replacement autolites at .035. I know that with a power adder the gap is lower but out of the box i think they are .044
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Feb 7, 2006
#13
  • Feb 7, 2006
  • #13
Mine are gapped at .045. With iron heads .054 is recommended by Ford but with Autolite 24's.
Your idle hunt is not from the gap. Too much fuel usually causes cold start idle issues. The ECC dumps more fuel at cold start up's. I had the same issue with the Pro-M bullet meter and 24# injectors. Tuning is the best cure. However play with fuel and timing settings until its tolerable.
HISSIN50
34
129
Feb 7, 2006
#14
  • Feb 7, 2006
  • #14
Joe, seems to me that 25's are the stock plug for GT's. 24's would be stock for Cobras.
legalize420
1,541
South Florida
Feb 7, 2006
#15
  • Feb 7, 2006
  • #15
764 for the cobra
HISSIN50
34
129
Feb 8, 2006
#16
  • Feb 8, 2006
  • #16
legalize420 said:
764 for the cobra
Hmmm, my bad. Since GT's use ASF-42's, which equate to a 25, I assumed a AWSF-32 would equate to a 24.
If I am wrong, I apologize for the misinformation.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Feb 8, 2006
#17
  • Feb 8, 2006
  • #17
Actually, from what I have experienced, once you get into bigger injector and maf combo's the eec doesn't add enough fuel on cold starts. This is why adding cold compensation fuel through our PMS's fixed our cold start issues.
Hot starts are where the eec dumps too much fuel. And pulling out cranking fuel in our PMS's fix that too
MysticKeith50
330
Feb 8, 2006
#18
  • Feb 8, 2006
  • #18
damn i thought my new sct chip i got would take care of this!!!
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 8, 2006
#19
  • Feb 8, 2006
  • #19
it will, you just need to get it tuned properly.
VibrantRedGT
424
154
Boca Raton, Florida
Feb 8, 2006
#20
  • Feb 8, 2006
  • #20
My car seems to be the opposite then. In the morning it surges. I take fuel out with the PMS and the hunt will stop.
1 of 2 Next Last
Autolite closing
  • FastDriver
  • May 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
TOOLOW91
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
