I was Wondering what is a good place for the wideband o2 sensor? Ive head of someone putting it on the crossover piece of the H-pipe but would that be effective? If not where else should it be placed? thanks for the time.
Yea mine is at 2 oclock as well.Stanger007 said:I've got my wideband in the passenger side collector clocked at about 2 o'clock per the instructions w/ the wideband.
19turbo95 said:What is involve as far as wiring goes for a wideband?
Yeah mine was just power and ground and then the plug that goes to the wideband. Mine has two connections that can go to the comp for data logging but i didnt hook them up yet im stand alone right now.final5-0 said:Not much really.
You just follow the directions in the kit.
2 to 4 hours maybe.
Grady
Each kit's different though.
Don 95Vert said:If the thermactor tubes are still going to the cats, then be sure it goes in FRONT of the cats. Extra air for the cats = false lean reading. Plus cats sometimes store and release 02 throwing readings off.
Fett said:This is a great topic, because it always generates different answers. I was searching for the best location for my LC-1 WB, I searched on here, the LC-1 forums, and eectuning forums. Each place had different opinions.
Some people say it needs to be close to the head, others say the further away from the head is better. Some say put it in the left (Drivers) pipe because that head tends to run leaner...others say it doesn't matter.
Me personally, I am going to install mine on the left pipe, down between the 45* bend and the X, about a foot and a half away from the stock o2.
I am going to watch this thread and see where it goes, I would be interested in reading some facts about it, as opposed to theories. Hopefully someone will chime in with an "expert" opinion.
