  • SN95 4.6L Mustang Tech
Wierd Sound....pls help!!
  • Thread starter Thread starter TorqueMonster88
  • Start date Start date Nov 15, 2006
TorqueMonster88
46
  • Nov 15, 2006
hey, everyone....i have a 2001 GT w/ 46,000 miles on it, and all of the sudden when i press the clutch it makes this wierd screeching sound....its not loud, but very faint.....when i let off the clutch it sounds fine and the gears change as normal...in fact the operation of the clutch is normal....its just when i push on the clutch is makes that noise, do i need a new clutch, will it go away or does it need immediate attention
blacksheep-1
322
Nov 15, 2006
  • Nov 15, 2006
It sound like the throwout bearing is giving up, which is odd, it should last past 46,000. Anyway, that means the tranny has to come out, so you might as well pony up for an aluminum flywheel and a clutch while you're there.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 15, 2006
  • Nov 15, 2006
You have time, it will take quite a while to completely fail. But when you go in there, yeah replace it all...
TorqueMonster88
46
  • Nov 15, 2006
soo...how much do u think it will cost to replace at a shop...
TorqueMonster88
46
  • Nov 15, 2006
soo...how much do u think it will cost to replace at a shop..with out the flywheel and clutch
the98stang
2,408
Clovis, CA
Nov 16, 2006
  • Nov 16, 2006
sh1t loads...at least $400 in labor and the part itself. The TOB won't hurt anything though. Just let it chirp. When you need to rebuild your tranny/clutch, you can replace it then.
blacksheep-1
322
Nov 16, 2006
  • Nov 16, 2006
The labor to change the TOB and the clutch is almost the same, you go through the same procedure you just unbolt about 10 more bolts, that's why everyone says to replace it if you go in there, the only real cost difference is the parts. It's not that hard of a job, most of us have done clutch changes in the driveway (or at the dragstrip, in the dirt...at night...in the rain..in the dark...) So it' s not like it's an impossible project, you just need to pay attention.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2006
  • Nov 16, 2006
It will cost A LOT
stangGT97
1,299
Boston area, MA
Nov 16, 2006
  • Nov 16, 2006
I paid $300 in labor for a full clutch install and everything was done perfect/professionally. You just need to shop around. What I did was go to a few places locally, get a price, then go to another shop and tell them what the previous shop quoted. That would get me a lower quote, then I finally went to the last shop (which seemed the most reliable of them all) gave the guy the previous quote and got myself a good deal. He was looking for work and to get his name out there so I made out like a bandit
As was said, dont pull everything out just to do the TOB. Do you have a T45? If so, you can buy a King Cobra clutch kit for like $150ish which comes with the tob, pressure plate and disk, then you just need the flywheel, new flywheel bolts, pivot ball and pilot bearing. The whole job cost about $600 for me.
TorqueMonster88
46
#10
  • Nov 16, 2006
  • #10
thank god for forums..hahaha....this is good info...took a load off my mind...thanx
Jsun3701
124
Virginia
Nov 16, 2006
#11
  • Nov 16, 2006
  • #11
You said its not too loud you can always grease it til you get the new clutch. Thats what I did, its been quiet for a month.
Rickey_Bobby
332
Sarasota, FL
Nov 16, 2006
#12
  • Nov 16, 2006
  • #12
another possibility...
Just another possibility...
I have seen clutches that arn't adjusted properly actually have the fingers on the pressure plate get pushed in so far that they contact the clutch and flywheel. As long as your clutch engagement isn't really high off the floor, your most likely safe. 90% of the time it is just the TOB. Just though I would give ya a heads up on the other 10%.
-steve
Jsun3701
124
Virginia
Nov 16, 2006
#13
  • Nov 16, 2006
  • #13
Grease the TOB dude.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
  • Gulftown980x
  • Jul 29, 2026
squeak93
9
1999 mustang rough idle and turns off when coming to a stop
  • 99GTSTANGG
  • Apr 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
Rainbow27
R
