hello, i am going to put the car back togethere now and i want it to have a little bit of a noticable idle to it. i have been hearing bad things about the motorsport cams and everything else it too expensive. i was thinking about using maybe a stock HO cam or thunderbird cam since i hear it is the same as the 93 cobra cam and use 1.7's with a torker II intake and either a holley 600 or carter 650 carb, shorty headers, O/R x pipe, force mufflers and a 5 speed. anybody know this question. not sure of the year of motor, i got it from company that sells used motors from wrecked cars. all i know is that it has a fuel pump eccentric to run a mech. fuel pump and it is a roller motor. i will be using either E6 heads or 289 heads. probably the e6's though since they are rebuilt.
Look into the TFS 1 cam. Less expensive than the alphabet cams and generally makes more power.
