Will 24# injectors work in my 88 5.0
jaackal
402
NJ
Got a cobra intake kit 70mm tb phenolic spacer cold air intake. Figured I would change the injectors should I go with 19# or 24# will i need to convert to mass air? What should I set the fuel pressure at?
You think i should go with the 24# injectors? Im replacing them because the car has 135k on it and i replaced 1 injector before, so while im doing the intake install i might as well install new injectors since everything is going to be apart.
Mustang5L5 said:
Except he can't put them in unless he burns a chip or converts to mass air.
Set your fuel pressure to 39psi with vacuum off.
Mike, i wouldnt say a chip is NEEDED for 24's.... with my combo, it runs perfectly fine and did great on the dyno! the only problem i had was that it leaned out after 4500, which was said to be my stock pump not having enough volume.. I bought a 255 pump and will make it back to the dyno sometime this week to see how it goes.... again, i directly swapped to 24's with no issues whatsoever, but you are right. he dont need 24's for what he has now
It can be made to work, but i have seen problems. We tried to put 24's ona friend's '88 and even though we got it to run nice and strong, we gained so much more power when we converted the car over to mass air.
