Will 93 Cobra Rotors bolt right on to a 90 GT?
I'm looking for a little extra clearance with the oem 93 Cobra wheels on my 90 GT. I've read where the Cobra rotors have a taller "hat" on them. Will the 93 Cobra rotors directly work on a 90 GT, or would I have to change something else also? Thanks for your help.
As far as i know they are direct swap..will even use same wheel bearings.
Quick check is to look up wheel bearing p/n on autozone.com. If they are the same, you are good to go.
I did that conversion on my 91 GT. The front rotors are a direct bolt in, if you keep the rear drums, you will have to use a wheel spacer so the back tracks the same as the front. I put the Cobra rear disc's on mine along with the longer Cobra axles (3/4") and it was good to go. Its a pricey upgrade, using the front and rear spindles and axles from a 94/95 is almost the same price, if not a little less and you'll have a 5 lug set up.
