i would like to get an aftermarket ignition. what i really want is a 2 step, but a rev limiter may work.
if i were to have a rev limiter set for 5500, would it work as a launch control device? i usually launch anywhere from 4500-5500 rpm's and i'd be willing to launch at 5500 all the time. if i hold the pedal to the floor, the rpm's won't go above 5500 rpms's right? so i could launch at 5500 rpm's, but shift right before that point while holding the pedal to the floor. the tach would bump against the set limiter while shifting, but the rpm's wouldn't go above 5500 rpms's right? does this sound reasonable. money is an issue, so that's why i am debating this meathod. do you have any other suggestions?
