what if this ford dealer does gear installs
nope. theres no way to do it with an IDS because it was not an as built option. on some years they can, i think 07 or 08+.
in CA we cant because it violates smog laws, since you are changing the operating RPM of a vehicle when putting it on a smog dyno.
no the gears are all ready in (ford wanted 800 just for labor) i got it done at a mustang shop. the only problem is for some reason my sct sf3 wont let me just change the gear ratio with out changing the trans press and **** points . i am not drag racing it or anything like that so the granny shift press is fine for me. i just want to change the gear ratio with out change anything else
ARE you serious?? you cant even do gear swap in CA anymore... Why would anybody live in that state..
theoretically yes, becuase when doing the dyno smog test you have to stay within a specific RPM range in 2nd gear at 25mpg. changing gear ratios can make you shift into 3rd which is an automatic fail on a manual car...
that being said its not part of the smog check, nor does it apply to my car.
