Will it work? I have the existing pulley and bracket. Will it bolt right up? Any differences? Thanks!
MdntRanger50 said:The plastic housing/reservoir is different between the two where the return line nipple is. The fox nipple points straight down and will interfer with the 94-95 bracket, can't get the return line on it. Either pump will bolt to either bracket. Pulley size is different and the 94-95 pulley sits in closer to the engine for the shorter front dress.
did you install it yourself? was the return line nipple L shaped or straight?kck6894 said:I put a fox pump on my car. Seems to work fine. The Fox pump is actually the same pump as the 94 up V-6 pump. I used my resivor and pulley and it went right in.
BlackVert said:did you install it yourself?
SorsCode said:the pump itself is the same. Just swap over your resivor.. removing the resivor is very easy.
Saleen302 said:Thanks! It worked out just like you said it would...
it's about time they made atlest one universial part
