KenneBell New Member Apr 14, 2005 158 0 0 San Jose California Apr 10, 2006 #1 Apr 10, 2006 #1 How can I upgrade my front swaybar? I have an SVO front swaybar but not sure if it will fit. Should I use it or use a GT swaybar?
88stangmangt Active Member Nov 25, 2003 2,332 1 48 Stafford,VA Apr 10, 2006 #2 Apr 10, 2006 #2 Im not sure about the svo it may i know i have a Turbo Coupe Front Sway bar on my 90lx.
Stinger Founding Member Jul 7, 2001 7,754 24 118 Basehor (Kansas City), KS Apr 10, 2006 #3 Apr 10, 2006 #3 Yes, it will work...
rd Founding Member Jan 12, 2000 3,316 63 109 Ocean Springs MS Apr 14, 2006 #4 Apr 14, 2006 #4 Should work, I have 5.0 car and straight 6 swaybars on mine. Only issue might be that the SVO had Lincoln lower arms that may be wider. Should still bolt up.
S SVOconvLX85 Member Mar 16, 2004 251 0 16 Vegas, for a while... Apr 14, 2006 #5 Apr 14, 2006 #5 I tried it on mine and the sway bar ends did not even match up close on my 91 arms. So I went and bought one for 15 dollars.
KenneBell New Member Apr 14, 2005 158 0 0 San Jose California Apr 15, 2006 #6 Apr 15, 2006 #6 Stinger, Which endlinks should i use, SVO or the 92 stang endlinks?
Stinger Founding Member Jul 7, 2001 7,754 24 118 Basehor (Kansas City), KS Apr 15, 2006 #7 Apr 15, 2006 #7 Get universal ones...you can buy them whatever length you want...just install the bar and measure how long they need to be.
1 140cilx Founding Member Sep 7, 2001 2,385 0 0 GA Apr 17, 2006 #8 Apr 17, 2006 #8 The Turbocoupe (at least the '87-88's) Swaybars are thicker than the SVO bars. I swapped my SVO's bars out for them sometime back. Stiffened it up noticeably. If you don't have either yet, get the TC bar front and rear and put them on your car.
