I've got an 88GT.. pretty stock, underdrives, no ac / smog, full exhaust, MAF conversion, 1.6 RR, (most likely an aftermarket CAM, gotta love the suprises that come in used cars) and I'm going to be having 4.10 gear installed soon replacing my current 2.73
Heres my question... I figure eventually I will need to upgrade my axles and I've pretty much decided on just hardened 28 splines. Money is kinda tight and I would like to wait if its not necessary..? So (should) I have a problem with 4.10s and stock axles? I plan on using my buddies slicks at the track too, so that is a factor as well.
Thanx for any and all input!
Jason
Jason
I believe that the hardend 28 spline mosers you speak of are around $230, cheap insurance and most guys have good luck with them into the low 11's and even 10 second range. Cheaper than a tow home and body repair, not too mention bruised ego
. Good luck.
