Will Ford Cover my tranny problem
sliver02GT
84
ok my 3rd gear grinds everything i go in 3rd, so i called ford and they said it would be covered under warranty unless they found abuse of the tranny, so i am wondering if they will still cover it w/ all the mods i have done to it...
had any one else had this problem please let me know
This is a local call made by the service manager or the regional Ford rep. With your mods, you may be screwed. When you modify a car that if that new you really need to be prepared to pay for this stuff out of pocket. All you can do is put your tail between your legs and hope for the best.
I would try to put everything back to stock, or as much as possible just to be safe. They can't say anything if you are stock, or they have to prove that whatever aftermarket part they are blaming it on is what is causing the problem. Also, put some crappy tires on instead of the Dr's. If they wanna be a**holes about it, they could say something about them.
That one law is a lot more complicated. While one section of that law does indeed require that the manufacturer prove that the aftermarket part is to blame, another section allows the manufacturer to void the entire warranty if there is any sign of abuse.
It is that other section of that law, which car/truck manufacturers are starting to use to their own advantage. Basically, if you make performance mods to your car, they can assert that you are making use of those mods. "Racing" is abuse.
The mod(s) itself/themselves don't even have to have any direct involvement with the failed component. Abuse voids the warranty on everything. :(
I have a blower and my dealer has not let me down yet on my extended warranty . Probably going to get them to install they 373s because I cant find anyone else to do it cheaper that I can trust to do it right .
i thought i replied to this yesterday, but i didnt. i brought my car to one of the worst(for voiding warranties) dealers in town(because they do the best warranty work) and even with all my mods and drag radials on the car, they rebuilt 2-3-4 gears for 1200 dollars and let warranty take the hit. The service manager said he was thinking about it, but then i asked him if he could prove in court that my mods broke my car. They let it go. I dont think they like me very much tho.
