  • SN95 4.6L Mustang Tech
Will Gears?......
  • Thread starter Thread starter pilks
  • Start date Start date Dec 7, 2005
pilks
109
  • Dec 7, 2005
i am planning on buying ford racing 4:10 gears for my 2004 gt (automatic)
my question is will these gears totally **** up my odometer
if i ever plan to sell my stang i dont want the mileage like tripled
thanks
sgarlic
3,085
Dec 7, 2005
  • Dec 7, 2005
Yes it will affect your speedometer/odometer. Since you have an automatic, you'll need a tune, or a hand-held tuner to have the PCM account for the change. A handheld tuner will not only allow you to fix that, but also mess with tons of other settings you'll probably appreciate (like shift firmness, timing advance, etc.)
pilks
109
  • Dec 7, 2005
http://www.mustangtuning.com/predator-410-gear-oil-kit.html
i was planning on gettin this kit (not bad for price n quality)
any idea on what a install will cost me
im sure i could do the predator myself
iv done alota research n i have some articles from
mustang magizines on this ****
i could always call predator n stuff ehhh?
sgarlic
3,085
Dec 7, 2005
  • Dec 7, 2005
The gears could cost anywhere from $200 to $800 to have installed. Some people have connections, some don't.. I suggest asking around your area til you make a friend.. it may save you couple bucks.. (2 phone calls got me free parts and labor on my FMS 3.73's.)
The predator you definately can do yourself. I would assume there's a manual included, and if that's not clear enough, they have a site with all sorts of info on it.
FORCED2DV8
458
Grand Rapids MI
Dec 7, 2005
  • Dec 7, 2005
Yep what he said, reprogram your speedo settings to match the gears, and youll be right ontrack
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 7, 2005
  • Dec 7, 2005
when i had my gears put on i already had the predator so the shop that did the install just reprogramed my shift points and gear ratio after the install but that kit you are planning on getting is a good deal
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 7, 2005
  • Dec 7, 2005
Yea, get a tuner. Us 5spd guys can either get tuners or a Speedcal. BTW, you guys think 550 is an alright deal for gears plus install? This includes everything
sgarlic
3,085
Dec 7, 2005
  • Dec 7, 2005
That's a pretty good sounding deal if it's at a reputable place. I think I said earlier, I was quoted around $600 from most places here (for labor only).. and everything seems to be a little more expensive here than everywhere else for some reason.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 7, 2005
  • Dec 7, 2005
did you try www.bieberfever.com in tempe i have bought some stuff from them but i never asked how much for gears when i used to live there
sgarlic
3,085
Dec 7, 2005
#10
  • Dec 7, 2005
  • #10
Nah I got mine free through a connection I had at a dealership.
L
laser2kgt
237
Laredo, TX
Dec 7, 2005
#11
  • Dec 7, 2005
  • #11
my dad knows a guy from the local ford dealer and he says they can do it here for $100, roughly the price of a dallas mustang speedcal.
04GT
284
Southwest Ohio
Dec 7, 2005
#12
  • Dec 7, 2005
  • #12
Or you could just put it up on blocks, put it in reverse, and put a brick on the pedal...like they did in "Ferris Bueller's Day Off"
hognutz
1,940
albany, oregon
Dec 7, 2005
#13
  • Dec 7, 2005
  • #13
if all you need is adjustment for the gears I would ask the dealership. I know on my dodge truck when I put 37's on it for $36 they were able to reflash the pinion factor to correct for the extra 5" of tire. I would expect to pay more for a mustang but I would rather have a ford reflash than a speedcal.
now on you car a tuner can do other things but it cost quite a bit more.
langod
34
Londonderry, NH
Dec 7, 2005
#14
  • Dec 7, 2005
  • #14
Wow -- apparently everything IS bigger in Texas -- including gear install prices. Up here in the Northeast everyone I've talked to has paid $200-250 for the install. (Which makes it about $400 or so total including the gears)
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
J
SN95 Hello new to this app
  • James S
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Habu135
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
