Will I have enough Alt power??
DanB93
66
Hello,
I'm getting ready to replace my stock speakers and also put in a new amp. I have already put in a Sony HU. The amp is a Jensen Power760 4-Channel 760 Watt Amplifier. I will be putting in some Infinity Reference 6030cs 6.5-Inch Components up front and some 5x7 just for fill in back. I want to ask if the stock 85 watt alternator will be sufficient? The car has no other mods. Its a 93 vert. LX.
On a side note what is good to replace the 3.5 speakers that will hold the 1" tweeters?
Thanks
your alt will be fine. just make sure you take a wire from the hu to the remote terminal on the amp to turn the amp off when you turn the car off if you dont youll kill your battery. the wire is blue on your hu thats the wire you run to the amp
